Post new topic Reply to topic  [ 105 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Samsung RAID LIF 128GB SSD, any adaptor for it?????
PostPosted: January 19th, 2015, 1:22
I think the thing that is not being clarified on this forum is that you cannot use the LIF to Sata Adapters that they currently sell online.
And even if they did sell the special/proprietary LIF to SATA adapter, you still would need to figure out other very complex things and purchase other things to hopefully get the job done. What is critical to add to the photos posted above, is that its not about cuting the Lif cable to the right width, but for the socket/ribbon pins to make proper contact with each other, then route to their respected connection.
e.g. The difference Voltages, Ground, and Data connections, other than add over-voltage/short-circuit protection to the connected SSD. Obviously not all LIF connections are the same. And by doing an excessive search online, nobody seems to actually have a real adapter to at least get the SATA or USB Connection to the SSD, let alone deal with other requirements. This is definitely not a DYI friendly task. Nor did I find anyone, but one that could do it in my area. Two of them told me they need to send it out so that i can get recovered.
Basically after going to five Computer Shops and Recovery places claiming that they could do it, I finally found one place that knew how to. And it was a very costly search.
Basically the last recovery place told me that many people end up burning-up their board by using the wrong adapters.
I was lucky to have mine still working after all the experimentation by others.
Save yourself the time and trouble and bring it to a recovery place you trust. Or if you do know what you are doing, your best bet is to find the same model Laptop and swap out the RAID-SSD Module. There is a risk however in using a different model or brand. There are also risks if you find the same Brand and Model Laptop. For example if the Laptop decides to re-initialize the RAID.
In the end it might be cheaper to hire a Professional that can actually do it; than to look for a matching laptop, go through the anguish of disassembling the laptops, taking the risk, etc. I found a place here in the States that sorted me out.
Good Luck!
PostPosted: January 25th, 2015, 1:11
My problem is THAT that board does NOT work. I need interfaces and connections that WILL work. Therefore any ideas on what and where to get parts is the information I require to get this SSD to function.
Thanks,
Terry
PostPosted: January 25th, 2015, 1:14
Ok I'll give up and throw this thing in the garbage.
T
PostPosted: January 25th, 2015, 3:41
Thanks,
Terry
I looked EVERYWHERE! I couldn't find anyone that sells or makes an adapter.
And again, I don't think you understand that it's not as simple as finding a connector.
The Laptop does a lot of other things when you have the SSD plugged in.
Things that an adapter will not be able to do. That's why they don't bother to sell it to the general public.
If all you care about is the connector, then I would call a parts distributor for your laptop
and order that specific part on the laptop (that is if they even sell it).
Otherwise find a dead Mboard on ebay and de-solder it. :)
This one company I went to in NY did have an adapter but they didn't let me see it up close.
They told me its not just about having an adapter, that you gotta do a lot more and be careful
in what you're doing in order to access it and pull out your files.
I would basically stay away from ever using that laptop and SSD again. It's more trouble than what it's worth.
PostPosted: January 25th, 2015, 4:35
T
Send it to this place:
Epic Data Recovery . com
They got tools recovered from an alien space ship. :)
PostPosted: April 28th, 2015, 11:29
Dear friends,
Same problem here. Dead Sony motherboard.
Samsung MZRPC512HBFU SSD
Need to read and recover data. Need desperate help.
Thansk a ton!
PostPosted: April 28th, 2015, 11:48
This adapter has worked perfectly for me on a few occasions. It's for the 24 pin drives.
http://www.amazon.com/SATA-Macbook-22pi ... B00JOXFMWA
PostPosted: May 3rd, 2015, 20:51
I have similar problem, can someone tell me how to change the SSD MZ-RPC2560 to sata. the connecter is 30 pins not 24
PostPosted: May 3rd, 2015, 20:56
PostPosted: May 3rd, 2015, 21:00
labtech wrote:
labtech wrote:
Have one of these as well (256GB).
Any suggestions as to what NOT to do in order to avoid wasting time on such drives?
PMs are welcome if anybody feels like today is Sunday.
Thanks in advance.
Forgot to update. Was able to recover the data two days ago.
Case closed.
I appreciate the individual who sent the one PM.
PostPosted: May 4th, 2015, 5:27
I have similar issue, the connector is 30 pin not 24 pins, kindly tell me how to change it to sata
PostPosted: May 5th, 2015, 4:29
I have Samsung SSD MZ-RPC2560/0SO PN: MZRPC256HADR-000SO,The drive is okay, but i need to copy the data fro it, it has lif connector , 29 pins, NOT 24 pins,
I could not find an adapter, I need to change it to Sata.
The picture of the ssd is
http://i58.tinypic.com/22kxw4.jpg
I found some thing on the NET:
http://i61.tinypic.com/k9f2x3.jpg
PostPosted: May 5th, 2015, 5:21
Obviously the card consists of two SATA devices, each with two SATA Tx/Rx differential pairs. You need to tap into each pair as you would for a normal SATA device, plus you need to supply +3.3V power to the card. There is no need to purchase an adapter.
BTW, here are direct links to your 2 images, without the images that "we might also enjoy":
http://oi58.tinypic.com/k9f2x3.jpg
http://oi58.tinypic.com/22kxw4.jpg
PostPosted: May 5th, 2015, 6:20
Thank you, can you guide me with the pinout of the connector
PostPosted: May 5th, 2015, 18:49
Can you upload detailed photos of both sides of your PCB?
What are the markings on the flash controller?
In which machine (model number of Apple, Sony, etc) was this SSD installed? Sometimes the service manual will have the pinout.
AISI, the PCB is powered from +3.3V according to the information on the label. There are two SSDs on the board, one on each side. Each SSD has its own SATA Tx/Rx differential pairs.
The photo you have provided has a 5V TVS diode across the 3.3V input. Using the markings on the diode as a reference, I have identified the +3.3V and ground points on the board. Please confirm this for yourself, as serious damage will result if I've got it wrong.
SD05-7, Diodes Inc, marking ZA, 5V, 350W, UNI-DIRECTIONAL SURFACE MOUNT TVS:
http://www.diodes.com/datasheets/ds31594.pdf
The SATA data pairs should correspond to the following pinout, either directly or reversed:
http://pinoutsguide.com/HD/serialATA_pinout.shtml
PostPosted: May 5th, 2015, 20:24
Thank you dear fzabkar, I need only 3.3 v, right?, I do not need the 5V
PostPosted: May 5th, 2015, 20:46
The Laptop is Sony , Model SVS13AB1GL pRODUCT NAME: SVS13A2APXS. I am posting the front and the back side, can you lablel mor clear the 3.3V. Thank you
PostPosted: May 5th, 2015, 21:43
it is pretty clear already, but here:
PostPosted: May 5th, 2015, 22:42
Here is a regular single SSD using the same flash controller (S4LJ204X01):
http://www.storagereview.com/images/Sam ... CB-Top.jpg
You can see how the SATA Tx/Rx pairs are wired to a regular SATA connector.
PostPosted: May 13th, 2015, 22:33
Data Recovery on a working RAID LIF about $$$+.
Data Recovery on burnt-out RAID LIF after you fried it (and if recovery is possible) about $1,500+ USD.
If you don't know what you are doing, or you have any doubts, DON'T mess with your SSD!
Let a pro do it for you.
Users browsing this forum: No registered users and 232 guests
