 Post subject: PC-3000 SSD - Is it worth it?
PostPosted: May 6th, 2015, 14:24
I am looking to get PC-3000 SSD as an addition to my standard PC-3000. I know there are so many issues with SSD's (unrecoverable Sandforce controller etc). Is it still worth investing in this equipment?
 Post subject: Re: PC-3000 SSD - Is it worth it?
PostPosted: May 6th, 2015, 14:28
there is NO Sandforce Tool yet.
and YES, it WORTH every single $ (in case if you get SSD drives ofcourse)
PostPosted: May 7th, 2015, 7:30
And will never be... for that kind of controllers
ddrecovery, think twice about it. Do you have enough SSD cases? There is a big problem due to different SSD vendors uses micro-controllers with encryption algorithm (like Sandforce).
PostPosted: May 7th, 2015, 10:27
This is most advanced tool for SSD on the market for now. The new SSD models (and controlers) constantly added by developers. We found it very useful. Of course, this is the metter of SSD case number You have.
:wink:
PostPosted: May 7th, 2015, 13:04
It pays for itself quickly if you know your local marked.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: May 7th, 2015, 19:41
There is nothing else on the market as good as PC3K SSD and you can buy it only when you have a case for supported drive.
PostPosted: May 16th, 2015, 9:29
The more people that buy this the better it will become. I use mine, not every day as we dont see many SSDs with FW issues that can be repaired with PC3000 but there are many that it does support. Intel with BAD_CTX .. still get these about 1 a month. So they more than pay for the TS contracts.
just my 2c
https://www.mjm.co.uk/
PostPosted: May 16th, 2015, 10:46
Just found out that as I have the PC3K UDMA, the PC3K SSD software is not supported. Its only now supported on PC3K Express since the split From PC3K Flash. Bugger :-(
PostPosted: May 16th, 2015, 14:28
@ddrecovery
But you get a good offer to upgrade old UDMA to UDMA-E
PostPosted: May 16th, 2015, 16:56
digisupport wrote:
@ddrecovery
More than a good offer I think :D Just need to decide on the 4 Channel by itself, or the 2 Channel plus SSD, both work out to be the same price.... If I didn't have to destroy the UDMA there would be no question..............
