 Post subject: WDC PCB Exists ? -> XXXX-771939-XXX
PostPosted: May 24th, 2015, 2:29
Hello ,
I was referring to data medics forums - > https://www.data-medics.com/forum/viewt ... ?f=25&t=13 .In This We Have a Line That For USB Number 771961 We Can Use PCB No 771959 or 7717939 or 771960 .I had ordered 771959 But the Holes Orientation is all different in the 771959 you cannot install it properly on 771961 .So i asked my supplier for 771939 and 771960 to which he quotes me for 771960 but said 771939 does not exist .Any Comments .
PS : For The USB 771961 The 7717959 Does Not Fit At All [ Do Not Buy It ]
 Post subject: Re: WDC PCB Exists ? -> XXXX-771939-XXX
PostPosted: May 24th, 2015, 5:46
yes, it will not install properly, but it will work properly you have to use 02 screws at head contacts and one on the right edge near the motor contacts.
give it a try, it will work.
good luck
Data Recovery Pakistan
PostPosted: May 24th, 2015, 6:14
good luck
It's true, it does "sort of fit" enough to make the connections and work :-)
PostPosted: May 24th, 2015, 7:32
good luck
+ 1
PostPosted: May 24th, 2015, 11:55
Hi ,
Everyone in My Case i think it spoiled one pcb due to this .Has Anyone tried 771960 on this .Also no one has responded to my 771939 question
PostPosted: May 25th, 2015, 3:49
Yes, the SATA PCB doesn't fit, but it is fitted by 3 screws.
I've never seen 771939, may be it doesn't exist.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: May 25th, 2015, 3:51
Amarbir wrote:
Hi ,
Sardar Ji,
I have not tested 771960, i have seen pcb 771931 on LPVX drives but not 701939.
PostPosted: May 25th, 2015, 5:06
I have never seen 771939 either.
PostPosted: May 25th, 2015, 5:21
Northwind And Baijaan ,
Why is Ace TS Docs Referring to 771939 then ?
PostPosted: May 26th, 2015, 14:41
Amarbir wrote:
Has Anyone tried 771960 on this.
This 771960 is completely compatible with 771961. It's full SATA-analog of 771961.
PostPosted: May 27th, 2015, 2:43
Well,
The Main Issue for my posting with this thread was explaining the world that 7717959 is not proper hole orientation as the usb pcb
PostPosted: June 3rd, 2016, 11:34
Hi Amarbir is right,
See attached picture
The spindle contacts are near the motor
I'm not able to find it again, but the board 771939 is it seen by me red color instead than green, maybe it is reallya a rare board
Though Marvell processor is the same as in the 771814 (USB) and 771820 (SATA equivalent for 771814), on these latter boards, the spindle connector is in the right place
what it does change is the HDA controller, maybe they could work.
Now I try
File comment: Bottom view of WD10TMVW-11ZSMS4
 Post subject: Yes WD board 771939 exists
PostPosted: June 3rd, 2016, 11:59
OK discovered the issue
board 771820 loads the ROM but next the drive won't spin
mounted the board on the donor, it won't spin anymore neither the donor drive
finally I've re loaded the original ROM on the donor and now it is back spinning and initialize fine
Looks like that one test with that mysterious 771939 board is needed, otherwise the only way is the transformation USB-->SATA
PostPosted: June 3rd, 2016, 12:09
Yeeeeh
I was right, the board 771939 does exists!
See this (ORIGINAL) declaration of conformity of Western Digital
but looks like it is the R/N of new ultra slim drives like WD5000MPCK
File comment: WD Declaration of conformity
WD-DECLARATION-OF-CONFORMITY.pdf [125.5 KiB]
Downloaded 474 times
PostPosted: June 3rd, 2016, 12:22
Well,
This post was ages ago .Now everyday i use a 771959 board and solve every case coming to my Office .I have some excitement going on here everyday www.facebook.com/chandigarhdatarecovery/ .Only three screws go onto this but i have filed the motor section of pcb with a file and made it fit the HDA assembly properly
PostPosted: June 3rd, 2016, 12:49
Hello Amarbir, have you modified the board?
can you kindly show / describe what you kindly mean? Or how you did it?
Thank you
Users browsing this forum: Google [Bot] and 58 guests
