 Post subject: pcb wanted for samsung s2 640gb. model hx-mu064DA/K22
PostPosted: May 25th, 2015, 20:06
Anybody got a pcb from one of these or an old full unit ?
I have same problem as this poster and I suspect the pcb.
viewtopic.php?t=18465&start=
Unit spins up the drive, think I can hear the arm move, no abnormal or horrible clicking noises.
blue led lights up for 30secs, then goes to 4 flashes, pauses, 4 flashes again ( anybody not what the four flash error code means ) ?
Pc fails to recognise / see hdd in disk management.
Continuity test on usb2 connector and ok. Connector pins ok, cant see any burning on board.
Ive looked for stock here in Australia and cant see anything
 Post subject: Re: pcb wanted for samsung s2 640gb. model hx-mu064DA/K22
PostPosted: May 25th, 2015, 21:04
I have some S2.. I will have to check the numbers
edit: 1st one is HXMU064DA/K42 2009.9 (SEC-HX-MU064DA(B) )
This one is just usb connector damaged. but works IIRC
I think this is all I have, The others I thought were S2 are not.
PostPosted: May 25th, 2015, 21:31
:D
thankyou for your reply.
that sounds great and your in Adelaide too, great stuff.
mine is eactly same.
hx - mu064DA/K22 2009.12
SEC - Hx - MU064DA(B)
should I pm you for your number and we can work something out ?
Users browsing this forum: No registered users and 223 guests
