 Post subject: ES2 Seagate drives terminal lock
PostPosted: May 20th, 2015, 6:57
I have got 2 ES2 Seagate drives with model no. ST3250310NS and PCB 100475720 REV A. Out of which 1 is OK and 2 are bad. In case when I connect OK drive I get terminal command by clt Z, but when I connect bad drives I could not excess terminal command and it gives error LED0000.... PCB`s is ok. When I connect only pcb , status becomes ready otherwise the drive show busy only.I have tried to short the pins also but no success.
Please help me what to do?
 Post subject: Re: ES2 Seagate drives terminal lock
PostPosted: May 22nd, 2015, 13:49
Gulati ,
Which Tool Are you Using these Days for seagate ? . Though In Terminal Mode It does Not Make any Difference what You Use
PostPosted: May 27th, 2015, 4:18
spildit it right . go with spildit :D :D :D :D
PostPosted: May 27th, 2015, 7:43
Galaxy ,
Where Are You From ?
PostPosted: May 29th, 2015, 9:50
Dear friends,
Thanx for your interest in the post. I tried all the steps which are mentioned in different different posts but could not get terminal command prompt.Even there is one method of shorting the pins ,that also failed.
If Any other suggestion, is welcomed.
Users browsing this forum: No registered users and 278 guests
