 Post subject: Info about SATA-USB compatible WD board
PostPosted: April 23rd, 2013, 5:39
can you tell me a SATA board compatible with USB board 2060-771801-002 REV P1?
It is from a WD5000BMVW-11S5XS0
Is 771823 compatible?
Many thanks!
Simone
 Post subject: Re: Info about SATA-USB compatible WD board
PostPosted: April 23rd, 2013, 8:01
yes compatible
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: April 23rd, 2013, 10:21
Thanks for the info!
Tested now.... fully compatible :)
PostPosted: August 23rd, 2013, 9:45
Is WD20NMVW-11W68S0 2060-771801-002 Rev A compatible with
771823 too?
PostPosted: January 28th, 2014, 16:40
Hi
The 2060-771931-000 is compatible with the 2080-771801-002?
ACELab partner
PostPosted: January 29th, 2014, 14:20
We should make a sticky thread about compatible sata boards for passports. Would save a lot of time if this info was readily available.
PostPosted: April 22nd, 2015, 2:40
can you please tell me, what SATA PCB board is compatible with USB board:
206-771801-002 REV A ?
771823 too?
As it is for 206-771801-002 REV P1?
Thanks a lot
PostPosted: April 22nd, 2015, 10:29
771823 too?
Thanks a lot
Yes, same
PostPosted: June 20th, 2015, 10:24
Hello.
Is 2060-771959-000 Rev A compatible with 2060-771801-002 Rev A?
Thanks.
PostPosted: June 20th, 2015, 14:41
According to the list, USB 771801 is compatible with SATA 771823
 Post subject: Re: Info about SATA-USB compatible WD PCB
PostPosted: June 21st, 2015, 5:43
There's no reason to keep in mind things like this. Just post clear readable photos of both PCBs.
PostPosted: June 22nd, 2015, 6:09
USB -> SATA
701605 - 701499
701615 - 701499
701635 - 701572
701650 - 701499
701675 - 701672 or 771672
771737 - 701692 or 771692
771754 - 701692
771761 - 771692
771801 - 771823
771814 - 771820
771859 - 771852
771949 - 771959
771961 - 771960, 771939, or 771959
771962 - 771931
771859 - (possibly 771852 or 771823 - untested)
PostPosted: June 22nd, 2015, 15:11
saltwater wrote:
USB -> SATA
701605 - 701499
701615 - 701499
701635 - 701572
701650 - 701499
771754 - 701692
771761 - 771692
771801 - 771823
771814 - 771820
771859 - 771852
771949 - 771959
771962 - 771931
I believe that was copied from this thread: https://www.data-medics.com/forum/viewt ... ?f=25&t=13 which was copied from the Ace website except for the last one.
I'm still hoping someone can confirm which board is compatible with the 771859 board...
PostPosted: June 24th, 2015, 3:26
Yes data-medics, that info is from data-medics forum, but i did not remember while i post.
Users browsing this forum: Google [Bot], michael chiklis and 136 guests
