 Post subject: Samsund HD520HJ
PostPosted: June 24th, 2015, 16:40
I have a problem on cloning a SAMSUNG HD520HJ 500GB 3,5''
Disk have a broken PCB (no spin) so I have changed PCB and swapped ROM
After it I have full access to data and start to clone it.
Problem is speed: is under 10KB/sec ....so need my full life to make a full clone :cry:
Both heads seem to work well (more than 99,9 % sectors are green).
Not module damaged
I have try to clean A-LIST with not results.
Some guru can give me some good suggestion?
 Post subject: Re: Samsund HD520HJ
PostPosted: June 24th, 2015, 18:00
have you tried in reverse ?
PostPosted: June 24th, 2015, 18:01
Yes same
PostPosted: June 24th, 2015, 18:27
I would guess you need to try a different PCB. Possibly there's a subtle difference which allows it to work but the read ahead buffer isn't working, causing it to essentially request one block at a time. Try a different one (closer if possible) and see if it makes a difference.
PostPosted: June 25th, 2015, 0:18
Was the donor PCB tested for issues prior to using on patient?
PostPosted: June 25th, 2015, 6:12
In fact no. Just bought PCB on a donor store.
I suppose was tested by seller.
 Post subject: Samsung HD520HJ reads very slow after a PCB / ROM swap
PostPosted: June 25th, 2015, 22:17
Did you look what happens on the COM port?
If not, post full terminal log right from the power-on moment and also what the drive says during the copying process.
Also mention the P/N. Though it could be just HD520HJ.
If so, post full FW version, like 1AxxxxxM.123 or real family (engraved on the PCB), but FV ver. would be preferable.
Otherwise guessing is quite useless, as I can come up with a dozen of possible issues right away.
PostPosted: June 25th, 2015, 23:09
If you upload a detailed photo of the original PCB, I could try to help you repair it.
Users browsing this forum: No registered users and 112 guests
