 Post subject: st3160812AS 3.AAH 7200.9 Terminal OUTPUT
PostPosted: June 29th, 2015, 4:15
Terminal Output
 üInterface task reset
4096k x 16 SDRAM
TONKA2 - 1_Disk    M-31   02-07-06 16:38
y
…ÂÿInterface task reset
4096k x 16 SDRAM
‚8
MÿInterface task reset
4096k x 16 SDRAM
²ÈÿInterface task reset
4096k x 16 SDRAM
0þInterface task reset
4096k x 16 SDRAM
‚ÂÉInterface task reset
4096k x 16 SDRAM
‚IÙþInterface task reset
4096k x 16 SDRAM
Ò   "þInterface task reset
4096k x 16 SDRAM
‚2’öInterface task reset
4096k x 16 SDRAM
q³þInterface task reset
4096k x 16 SDRAM
’’’ÉInterface task reset
4096k x 16 SDRAM
Repeating without STOP or Terminal
If PCB Changed the Same OUTPUT
Let me know the Problem and Advise
 Post subject: Re: st3160812AS 3.AAH 7200.9 Terminal OUTPUT
PostPosted: June 29th, 2015, 7:49
is it mechanical or something else?
Experts pls
PostPosted: June 29th, 2015, 9:04
Did you move the ROM with the PCB? Are you certain that it is the original PCB?
PostPosted: June 29th, 2015, 9:09
Both PCB Output same
No Rom Transfer
PostPosted: June 29th, 2015, 11:24
I think you need to understand the basics for Seagate troubleshooting.
If you swap the PCB without transferring the ROM, then you're just spinning your wheels. (Unless you're VERY experienced and have the proper tools and knowledge).
If you want to rule out PCB then you NEED to transfer the ROM otherwise you're only wasting your time.
If the data is of any value, please pass this drive to someone who knows what he's doing.
PostPosted: June 29th, 2015, 11:56
transferring the ROM done but same output
Users browsing this forum: Bing [Bot] and 38 guests
