 Post subject: Stiction marks appear as tiny circles under microscope?
PostPosted: June 29th, 2015, 4:09
Hi there
Was doing some dead drive autopsying on a:
Seagate Barricuda 2000GB
ST2000DM001
9YN164-302
Had a massive amount of trails, and stiction marks on every platter, for the first time i got to try out my new microscope on some stiction marks, then i noticed something freaky.
The stiction mark appeared to be a series or tiny circles at max (90X) zoom. :shock: :shock: :shock:
Circles? Why circles? Can anyone explain this strange phenomena to me?
File comment: Here's the best looking image i found.
 Post subject: Patterned media (bit-patterned media, BPM) under microscope
PostPosted: June 29th, 2015, 5:23
This drive uses patterned media (aka BPM).
 Post subject: Re: Stiction marks appear as tiny circles under microscope?
PostPosted: June 29th, 2015, 6:26
Fascinating! So each circle is a bit.
https://en.wikipedia.org/wiki/Patterned_media
http://www.toshiba.co.jp/rdc/rd/fields/11_e09_e.htm
Thanks for the input. If anyone else is wondering what microscope i used, it was an Amscope:
http://www.amscope.com/microscopes/3-5x ... amera.html
PostPosted: June 29th, 2015, 11:53
And this pattern on the posted picture is not a stiction mark.
PostPosted: June 29th, 2015, 20:56
Enlighten me. What do we call it?
PostPosted: June 29th, 2015, 21:51
I would have thought an individual bit would be a LOT smaller than this.. but I have no experience, research or knowledge to actually back this up. I notice on the link you posted they used a SEM to see the bits.
PostPosted: June 30th, 2015, 1:14
I also imagined they would be a lot smaller, strange they showed up on only 90x zoom.
After fiddling around with the scopes software i was able to get pixel measurements, at max (90x) zoom.
1mm at MAX zoom = ~750px
1 circle at MAX zoom = ~23px
23 / 750 * 100 = ~0.0306mm
or ~30.66 μm (micrometers)
or ~30666.6 nm (nanometres)
So yes these circles are about 3,000 times larger than the '10nm' quoted from that toshiba link. (If my math isn't off.)
File comment: 1mm compared to circle. (Circle is zoomed.)
PostPosted: June 30th, 2015, 9:22
Basically duplicating my PM to CleanestRoom here, but anyway:
Yes, these dots aren't magnetic grain for sure.
I probably should sleep more, but I asked CleanestRoom about the microscope as I thought he got his hands on some sexy equipment and decided to (ab)use it properly :)
This is an amateur judgement, but I believe optical microscopes can't produce such a detailed picture of the grain on a modern platter due to their diffractional limit.
PostPosted: June 30th, 2015, 9:50
Dmitri wrote:
but I believe optical microscopes can't produce such a detailed picture...
even with digital camera connected to it ?
details from the link above:
3MP digital camera captures still images, streams live videos and is compatible with Windows XP/Vista/7/8, Mac OS X, and Linux, as well as user-friendly advanced software for Windows offers Stitching, EDF, video recording "and measurement functions"
PostPosted: June 30th, 2015, 17:59
Using just the measurable parameters (max transfer rate, outside diameter, RPM), we can arrive at an upper limit for the size of a "bit".
(210 MB/s) / (7200 per minute) / (3.5 inch x pi) = 50 bits per um = 20 nm per bit
http://www.google.com/search?q=210+MB%2 ... its+per+um
Obviously the size would be lower if we were to account for the "overhead" bits.
According to the product manual (http://www.seagate.com/staticfiles/supp ... 686584.pdf), the maximum recording density is 1807kFCI (kilo flux changes per inch).
That works out to 13.6 nm per flux change.
PostPosted: June 30th, 2015, 23:32
Software only measures pixels, there's no electronic reading of the scopes zoom so calculations must be done manually as I've done.
Hypothetical. :mrgreen: I'm a billionaire, and i want a SEM that can read to less than 10nm, how much might that cost?
PostPosted: July 1st, 2015, 0:28
http://www.technicalsalessolutions.com/items.php?CID=3
There is one here for 8 grand...
http://www.labx.com/item/hitachi-s-2400-scanning-electron-microscope/624867
of course I haven't looked at specs, but it would do me :)
not insanely expensive, some bigger DR labs could probably afford one
Users browsing this forum: Google [Bot] and 65 guests
