 Post subject: External HDD become RAW and I don't like to format it :(
PostPosted: July 5th, 2015, 9:43
Hello.
My External HDD become Raw and I can't open it, In Windows OS to show me "Format disk" and I want to know can I fix it without format?
I attached some photos and need your advice.
How about below link :
http://html5.litten.com/how-to-fix-exte ... ecame-raw/
I did it and show me "Deep Search" without any partition and I did Deep search.
Can it lost my data?
 Post subject: Re: External HDD become RAW and I don't like to format it :(
PostPosted: July 5th, 2015, 10:51
knowing where "on the space" is located, one would be able to give you
advice on a pro in your area ....
Never the less this can be either a simple issue or something serious.
Even trying to clone that drive could make it worse - a correct diagnose
from a pro is the best solution ....(and no collegue, or friend of a friend
or relative)
Its as simple - if data is valuable for you ... get proper diagnosis,
otherwise you might loose your data.
whoever suggests to go on with your own DIY doesnt care for your data.
PostPosted: July 5th, 2015, 14:27
Any tools or way?
PostPosted: July 5th, 2015, 20:35
What model external is it?
PostPosted: July 6th, 2015, 3:28
it is Silicon Power.
After Deep search it show me "Rebuilding BS" and after it when I select "List" not any file shown
PostPosted: July 6th, 2015, 4:29
Can you show us a Partitions window in DMDE?
http://dmde.com/
PostPosted: July 6th, 2015, 8:07
Ok, not 100% but from I know about these, they don't have any encryption. Is this correct?
PostPosted: July 7th, 2015, 11:59
Yes, if photorec isn't at least finding some files in RAW it's likely an encryption issue. Can you provide a picture of the original USB bridge board?
That or this is a simple sector size issue. Are you directly SATA connected, or using some sort of USB adapter? I know that some adapters can't handle 4K sector drives properly.
PostPosted: July 11th, 2015, 6:45
As I said, It is an External HDD.
PostPosted: July 13th, 2015, 17:10
Could be external sata.
Users browsing this forum: No registered users and 31 guests
