 Post subject: Western Digital Bios Problem
PostPosted: July 9th, 2015, 7:05
I have two harddrive Western Digital 320 GB 2.5 with same PCB 2060-771682-004 Rev A
One of is completly crashed and Windows can not see this Hard Drive
other harddrive is working perfectly I change the PCB and change the bios too with working PCB but still do not work
I think the bios is damaged because the other working bios is work with two same PCB s
Please help if you have any idea
Is there a way to fix the bios
 Post subject: Re: Western Digital Bios Problem
PostPosted: July 9th, 2015, 7:47
i think bios is correct. problem in hdd. if you need data from this drive then bring to data recovery company.
PostPosted: July 9th, 2015, 12:53
merhaba
did you try the other pcb without changing BIOS, does it spin that way ?
RAID/Server Recovery
PostPosted: July 9th, 2015, 13:06
Yes I try it starts to spin but not to start recognize. So Operating system does not give any sign about harddrive.
But another detail** healty bios (I think ) Works with two PCB without any problem spin and recognize..
PostPosted: July 10th, 2015, 12:44
İ have same problem..
i got same model wd wd20ears-00mvwb0
but the PCB rev is different.
swapping and rom transfer is useless..
Help please..
Yabancı mı var a.q. Türkçe konuşsak olmaz mı?
PostPosted: July 11th, 2015, 4:22
Türkçe konuşalım,
Bana özetle bu harddiskin biosu lazım bunların benzersiz olduğunu biliyorum onun için birebir aynı seri olmalı, bulamazsam en kötü diski değiştireceğim..
Sizdeki PCB noyu paylaşırsanız bizde varsa ben yardımcı olayım mikail13..
Saygılarımla
PostPosted: July 11th, 2015, 5:52
is the main IC chip number same?
Ana çip aynı mı?
PostPosted: July 11th, 2015, 8:01
Tekrar selam hepsinin PCB numarası aynı sadece 1 HDD sağlıklı çalışıyor ve dataları gösteriyor
Hi Again all the PCB numbers are same, one of the harddrive ( right one ) work as well and can Access data.
PostPosted: July 13th, 2015, 1:33
Is Changing bios and ICC fix this problem
PostPosted: July 13th, 2015, 4:51
most likely problem is not PCB, could be FW, bad sectors or heads.
If data is important i would suggest to contact a DR company.
Users browsing this forum: Pi0tR and 81 guests
