 Post subject: Samsung 2TB HD204UI PUIS enabled
PostPosted: July 17th, 2015, 4:09
Hi, maybe someone could help me disable PUIS on Samsung HDD? i have two of them now broken by win10 :D
one is HD204UI, i have successfuly connected terminal to it, but it will not spin up, after i give spinupp comands. so thinking of disabling PUIS manualy via ROM.
other has same situation but is HD103SJ + in adition if i try to spin it up using terminal or anythign else MOSFET that controls -5V gets burtn, but i do not see any other damages to preamp or drivers, so am at a bit of lost. :) many thank for any thoughts :)
File comment: 2TB hdd rom
2TB_ijungtas.rar [185.99 KiB]
Downloaded 901 times
File comment: 1TB hdd rom
1TB_ijungtas.rar [162.92 KiB]
Downloaded 795 times
 Post subject: Re: Samsung 2TB HD204UI PUIS enabled
PostPosted: July 17th, 2015, 5:09
sorry :) solved :)
PostPosted: July 17th, 2015, 5:54
I've arrived at my own solution in the meantime. I cut the ROM out of the official F4EG update and discovered that it differs from yours in a few areas. Your ROM's checksum was also in error AFAICT.
How did you solve your problem?
PostPosted: July 17th, 2015, 19:10
Please tell me how you solved it. I've been dealing with this since last december when Windows 10 bricked my drive.
Please post your solution. Thank you.
PostPosted: July 22nd, 2015, 4:33
I don't have the capability as a new user. Can someone please send a PM to andrius to ask if he can come back and explain his solution?
EDIT: Hm, nevermind, I guess this second post unlocked the ability to send PMs.
PostPosted: February 28th, 2016, 17:11
See http://www.hddoracle.com/viewtopic.php? ... 8192#p8192
The PUIS flag (0xAA) is stored in the FIPS section at offset 0x3021. The checksum word at 0x37FE is also adjusted.
00003000  46 49 50 53 9B 00 00 00 32 2E 30 30 30 20 20 20  FIPS›...2.000
00003010  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00003020  FF AA FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿªÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000037E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000037F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF D8 EC  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿØì
I suspect that the actual problem may be this area:
00041FF0  FF FF FF FF FF FF FF FF FF FF FF 00 01 00 C2 F1
The original ROM code looks like this:
00041FF0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF C2 F1
PostPosted: February 28th, 2016, 17:21
Hey fzabkar, thanks for sharing this.
I still have both drives stored away. But last I checked I even struggled to get anything from them with a TTL adapter. You suggested that I might have stressed the pins. If I got the drive to communicate via TTL, is this a fix I could do myself?
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 57 guests
