My Seagate internal HDD is not detected by bios
My Seagate internal HDD is not detected by bios, below is detail 17%  17%  [ 1 ]
ST500DM002 0%  0%  [ 0 ]
P/N: 1BD142-302 0%  0%  [ 0 ]
Pls help me recover data 83%  83%  [ 5 ]
Total votes : 6
 Post subject: Hi my seagate Seagate st500dm002 not detected by bios
PostPosted: July 22nd, 2015, 15:07
Hi
ST500DM002
P/N: 1BD142-302
Firmware:KC45
data Code:13144
attached disk PCB image & HDD detail image
PLS help
 Post subject: Re: Hi my seagate Seagate st500dm002 not detected by bios
PostPosted: July 22nd, 2015, 15:08
Rgds
Chand
PostPosted: July 22nd, 2015, 15:34
is it spinning ? is it clicking/making strange noises ?
PostPosted: July 22nd, 2015, 15:43
999 times out of 1000, you will need professional data recovery assistance. It is unlikely that you will be able to revive the drive without tools to work with the service areas. Depending on the root cause, it could be a minor recovery for less than $500.
PostPosted: July 22nd, 2015, 16:28
I find it interesting that this topic is a poll. Where's the "Should've bought a Toshiba instead" option? :D
In all seriousness though. These drives are known to be problematic. If it's not making any strange noises, just spinning normally, it could be a media cache issue or translator problem. But, very hard to diagnose and even harder to repair without pro tools.
PostPosted: July 23rd, 2015, 0:59
Some clicking noise, if connected as secondary HDD, win 7 disk management shows drive 0, with 3.9GB capacity, but if i click shows disk i/o error.
Is this a problem with logic PCB board, if so where can i get this PCB?
PostPosted: July 23rd, 2015, 2:05
Extremely unlikely PCB, 99% certainly physical heads issue.
PostPosted: July 23rd, 2015, 4:32
Yep, it's heads.
PostPosted: July 23rd, 2015, 9:39
What do you see in Terminal ?
PostPosted: July 24th, 2015, 1:21
Still not used Terminal
Preparing USB cable (Sort of old Nokia Cell data cable)
PostPosted: July 29th, 2015, 4:21
Used Nokia CA-42 USB data cable for terminal, but when connect HDD, not getting terminal prompt .i.e F3T>
When power connected to HDD, getting below log in terminal screen, pls help what next
Boot 0x10M
Spin Up
FAIL Servo Op=0100 Resp=0003
ResponseFrame FFFF 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0000 0000 0000 FFFF
ResponseFrame 2EA0 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0000 0000 0000 0004
0000 0000 000
0000 0000 0000 0004
0000 0000 0000 0004
0000 0000 0000 0004
0000 0000 0000 0004
0000 0000 0000 0004
0000 0000 0000 0004
0000 0000 0000 0004
0000 0000 0000 0004
PostPosted: August 29th, 2015, 4:24
You must short read pins.
and get F3 T>
