 Post subject:
PostPosted: November 1st, 2004, 4:26
Sure he does.... :evil:
 Post subject:
PostPosted: November 1st, 2004, 9:06
i am also sure he dose!!!!!! :evil:
 Post subject: Re: the lowest price to selling pc3k&hrt and trainning
PostPosted: November 1st, 2004, 10:59
jerry wrote:
if you need repair tools about hdd .if you didn't want spend much money.if you need help from pc3k expert ,pls connect with me
connect with me sooner you'll be a expert on hdd repair sooner
Hi Jerry,
give us an example of your training - your most cunning stunt.
PostPosted: November 3rd, 2004, 10:34
please talk more detail.I don't knom which you need. :agree:
PostPosted: November 3rd, 2004, 10:41
Ok here is an example problem :
MPG3409AT - heads knock at start up but after 60 secs knocking stops.
You will know that heads map is wrong and more ......
Tell us how to proceed to a working drive so data can be recovered.
PostPosted: November 3rd, 2004, 21:53
[quote="fujimax Ok here is an example problem :
Tell us how to proceed to a working drive so data can be recovered.[/quote]
your hdd is fujiston.that's because the head controller is bad so at first you must rewrite the
BIN file .if it dosen't work ,ok ,find the same size hdd then change the head.i hope to see your solution
PostPosted: November 4th, 2004, 1:52
:cool: :cool: :buhahahaha:
Good training.
:good:
PostPosted: November 4th, 2004, 7:04
jerry wrote:
your hdd is fujiston.that's because the head controller is bad so at first you must rewrite the BIN file .if it dosen't work ,ok ,find the same size hdd then change the head.i hope to see your solution
OK, I read the native BIN file compared it to another identical drive and they match- Also original pcb works good on another drive so we can conclude that BIN file is OK.
Must I now do head change ??
Nothing else to check before this ?? :roll:
I think viper knows something........
There are more questions than answers,
and the more I find out the less I know .... :serenade:
PostPosted: November 4th, 2004, 16:21
:o cool training!!! should I try many many adaptive files for this 40GB MPG? :iknow:
BTW My solution is to "FUJITSU" :evil: shoot it :)
 Post subject:
PostPosted: November 5th, 2004, 3:16
Are we allowed to advertise here ??? :evil:
-BR-
 Post subject:
PostPosted: November 5th, 2004, 5:33
-BR-
If it belongs to you, I am sure you can sell it here :good:
If it belongs to someone else and you selling it ..... :abuse:
I suspect the training session has ended :tease:
There are more............ :serenade:
 Post subject:
PostPosted: December 11th, 2004, 20:13
POST ERASED
 Post subject:
PostPosted: December 12th, 2004, 5:21
Good one Tony,
The question was about a Fujitsu MPG3409AT.
My experience with clicking Maxtors - they toast.
 Post subject:
PostPosted: December 12th, 2004, 12:36
POST ERASED
 Post subject:
PostPosted: December 13th, 2004, 2:01
Tony wrote:
Well, after 4 beers to me any Fujitsu is like maxtor! :roll: :druunk: :buhahahaha:
Posted 12/12/2004, 11:37:
There is a trick with Fujitsu, but I can't share it. Works 90% of the time.
Yes, I figured that ... :druunk:
Agreed, nobody shares their tricks, that's why the guys with
the best tricks are called magicians - but mostly these are just illusions.
 Post subject:
PostPosted: December 13th, 2004, 11:27
POST ERASED
 Post subject:
PostPosted: December 16th, 2004, 17:18
with mpg just resolder Cirrus Logic
 Post subject:
PostPosted: December 16th, 2004, 23:56
POST ERASED
 Post subject:
PostPosted: December 22nd, 2004, 21:57
hello, everyone.
 Post subject:
PostPosted: December 28th, 2004, 10:16
resolder Cirrus Logic is not a good idea
msn messenger:mba2002@hotmail.com
Posted 28/12/2004, 22:19:
we can talk about hdd repair
msn messenger:mymba2002@hotmail.com
Users browsing this forum: DRUG, Google [Bot] and 307 guests
