 Post subject: Canvio 4tb USB3 "Semaphore timeout error"
PostPosted: August 4th, 2015, 17:24
I have a couple of Canvio 4TB USB3 drives I picked up on clearance at Staples.
When either one is connected to a USB3 port they will freeze (win 8.1) requiring AC reset, or in Windows 10 they give me a "Semaphore timeout error".
They seem to work fine on a USB2 port.
I've seen mention of this error before catastrophic failure on these drives.
However it seems to me like a firmware bug in the enclosures rather than a physical issue.
Anyone experience this?
 Post subject: Re: Canvio 4tb USB3 "Semaphore timeout error"
PostPosted: August 4th, 2015, 18:07
connect it directly to the computer and you'll find out (unless there is no a SATA interface inside the enclosure)
PostPosted: August 5th, 2015, 2:10
Thanks for suggestion I found the problem, it was SMART error monitoring applet.
Disabled problem solved.
Users browsing this forum: Google [Bot] and 213 guests
