 Post subject: Segate 7200.12 suddently not recognised from bios
PostPosted: August 8th, 2015, 10:00
I have a Seagate Barracuda 7200.12 1 TB ST31000528AS firmware cc49.
This hd was getting an increasing number of reallocate sector count when checking SMART the drive with Crystal Disk Info but I was still using fine (not really smart from me, I know and now I need some files from it). Until yesterday ( that is 2-3 years of using it) the disk after starting normally disappeared from my windows 7 computer. I restarted the computer and it wasn't detected from bios.
The drive spins up and doesn't make any strange noises so I suppose there is no physical damage, as far I can tell.
I decided to use an old computer I have that has a serial port to try I see if I can connect to the drive.
I managed to make a cable with the female pins of an old RS232 cable to connect the serial port to the rs232 port of the hard drive.
I set up the Hyperterminal program with 38400,8,none,1 setting connect the hard drive to power. Disk starts, hyperterminal says its connected and I send the ctr+z command and I get nothing.
I tried swapping the transmit and receive cables but nothing.
I tried connecting the rt and tx cables together to test the seriel port and it works, I can see what I type in the hyperterminal, so the serial port is fine.
Can you help me?
 Post subject: Re: Segate 7200.12 suddently not recognised from bios
PostPosted: August 8th, 2015, 11:59
The procedure I'm following is the one from here
PostPosted: August 8th, 2015, 15:46
I just found out why it's no accessing the drive. The rs232 generates the right form signal but not the right amplitute to TTL values. Thus I would need a rs232 to TTL Converter. Just ordered a USB to rs232 TTL dongle and now I have to wait for it to come.
PostPosted: August 8th, 2015, 17:54
i hope you know what doing
PostPosted: August 8th, 2015, 18:11
That procedure applies to a 7200.11 drive. The same procedure will damage your 7200.12 firmware if the non-resident G-list is not empty. Start by obtaining a terminal report, without issuing any commands that write to the drive.
PostPosted: August 9th, 2015, 4:34
What commands can I use to get that report?
There is a lot of info about 7200.11 drives but the info for 7200.12 is very disperse
PostPosted: August 9th, 2015, 4:37
Not really. First I need too get connected to the drive.
Do you have a better procedure or tutorial for a Seagate 7200.12?
PostPosted: August 10th, 2015, 6:41
I've got the usb-ttl dongle and connected a cable from the rx connector and to the tx connector from the drive and from tx conector from the dongle to the rx connector of the drive.
I use putty with the settings 38400,8,1,none,none
power up the drive,open putty, connect, press ctrl+z and still nothing.
I read something about shorting the read channels, do I have to do it?
PostPosted: August 10th, 2015, 7:27
This is the board 100535537 REV A:
http://i.imgur.com/MM170b8.jpg
http://i.imgur.com/WYbs8oD.jpg
PostPosted: August 10th, 2015, 7:49
connect, open putty and then power up the drive
post the log here
PostPosted: August 10th, 2015, 8:47
Nothing and know I've got the click of death
PostPosted: August 10th, 2015, 9:48
I shorted the read channels and this is what I get:
Rst 0x20M
Servo Processor Is Reset.
RW: Disc Ctlr Initialization Completed.
ExecuteSpinRequest
ASCII Diag mode
F3 T>
ASCII Diag mode
PostPosted: August 10th, 2015, 10:08
I've got to this, then stops typing commands and I still hear the clicks of death
Rst 0x20M
ExecuteSpinRequest
ASCII Diag mode
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 10.531 secs
F3 2>
ExecuteSpinRequest
HighPowerMode U
PostPosted: August 10th, 2015, 11:11
Also managed to get this. After that it just hangup
F3 T>V40
Nonresident GList 0 entries returned
Total entries available: 0
PBA Len Flags Phy Cyl Hd PhySctr SFI
PostPosted: August 10th, 2015, 21:50
Can you show us P-List terminal log by entering command V10 ?
Upload the log on forum as .txt file
My firmware database:
Users browsing this forum: No registered users and 61 guests
