 Post subject: Swapping PCBs on WD2500JS SATA drive-unsuccessful
PostPosted: August 21st, 2015, 11:08
We had a WD2500JS SATA hard drive that was not too old (3-5 years perhaps) and one day one of my colleagues noted
that there was a BSOD on the screen. After shutting down the workstation and restarting, it reported that there was
no SATA drive on channel 0.
Upon inspecting the hard drive, I noticed that it was not spinning up at all, no power was getting to the drive electronics.
A small burn mark on the external PCB was visible at close inspection.
Since we did not have a recent back up of the data, I thought I would try a trick that I used to use years ago with ATA/IDE
hard drives: Finding an identical (or nearly identical) hard drive and swap the PCB board.
I did this and indeed the drive did power up. However, the BIOS showed a HDD failure. The PC BIOS reported this drive
as a WDC ROM Model HAWK instead of the proper WDC WD2500JS-98MHB0 which would have been the true BIOS signature.
I removed the drive and connected it to a USB-SATA converter. I connected this to another PC running Windows and it detected
the hardware and disk drive, however it was again reported as a WDC ROM Model HAWK. No drive letter appeared in the Windows Explorer
and DISKMGMT.MSC did not recognize the drive, even after a complete rescan/refresh.
Visually the PCB boards look the same, they show the same revision on the PCB side:
The original drive shows the following:
MDL: WD2500JS-75NCB3
Date: 29 JUL 2007
DCM: DSBHNTJCHN
LBA: 488281250
The swapped drive has the following:
MDL: WD2500J8-98MHB0
Date: 18 MAY 2007
DCM: H8BHNT2AHN
LBA: 488397168
I notice there are some jumpers on the drive, the default is to have J1/J2 jumpered, enabling SSC (spread spectrum clocking). I tried
removing this jumper and also the other combinations (PM2: controlled spin-up, 150MB/s transfer speed). I did not see any changes
to the recognition of the drive when these were changed.
My question is: is there any way to get the original drive working again by using this PCB or do I need to have a PCB which is verbatim
to the original one?
I would rather not have to resort to a data recovery service unless it is not expensive (more than a couple hundred dollars).
Thanks so much.
Mike
 Post subject: Re: Swapping PCBs on WD2500JS SATA drive-unsuccessful
PostPosted: August 21st, 2015, 17:31
Sounds like you need pro help
Try 300dollardatarecovery.com
Brian should be able to sort it for $300
PostPosted: August 21st, 2015, 18:13
Your pcb swap resulted in a high expectancy outcome. The firmware is different.
PostPosted: August 21st, 2015, 18:16
Is there a way I can swap the firmware? I have heard chip U12 has this firmware.
PostPosted: August 21st, 2015, 18:25
Sure, if the IC is fine, chances are favorable.
PostPosted: August 23rd, 2015, 22:30
but the pcb structure of the PCBs are different. So U12 rom replacement will NOT be succesful.
PostPosted: August 24th, 2015, 2:57
I would be careful with any drive using pcb 701335 (and 701265, 701292 and perhaps a couple of others of the same era), because they are prone to fail in such a way that they supply overvoltage to the preamp on the -5V line, which can produce a range of problems from temporary read failures to permanent data damage by write channel and preamp damage.
so i advise checking -5V on both pcbs, and not only just check, but let it powered on (only the pcb without hda) for a couple of minutes and check the voltage for runaways. Using an oscilloscope is the best because you can detect short spikes and slow changes too.
Users browsing this forum: No registered users and 67 guests
