 Post subject: Seagate problem data recovery
PostPosted: August 25th, 2015, 16:52
hi gurus, what you think about this one?
drive had heads swap and not booting ST2000 DM
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
TCC-0020[0x000042FF][0x000042FF]ZZZ[0x00006389][0x00006389]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddW
PreampFaultStatus = 0000YW
PreampFaultStatus = 0000YWMMMMMM
RECOV Servo Op=0155 Resp=0005S
RECOV Servo Op=0055 Resp=0005xxxxZWZWZWZWZWZWZWZW
Recuperacion De Datos Dominican Republic
 Post subject: Re: Seagate problem data recovery
PostPosted: August 25th, 2015, 18:00
Had a similar output after headswap, media damage on that one.
http://www.rescue-it.se
PostPosted: August 25th, 2015, 18:11
That error code is described in this Seagate Terminal list: https://www.data-medics.com/forum/seaga ... -t901.html
 Post subject: Seagate data recovery
PostPosted: August 25th, 2015, 21:46
The drive can't read the SA. Another question is whether it sees the servo wedge, but that isn't something to tell from the log.
