 Post subject: ST500DM002 Donor Match Doubt - Pls urgent
PostPosted: September 1st, 2015, 0:57
My HDD Spec
Seagate Barracuda 500GB SATA
Model ST500DM002
S/N S2A6M2A4
P/N 1BD142-302
Firmware KC45
Date Code 13382
Site Code WU
Damage in PCB
So To Replace the PCB Donor Drive Differ in Date Code & Site Code also some codes mentioned in the picture
is these numbers (Marked in Square Box) to be matched?
Pls Clarify the doubt
Note: Can i replace the Damaged component(Broken) from another board ?
File comment: 704C_TOP
File comment: 704C_Inner Side
 Post subject: Re: ST500DM002 Donor Match Doubt - Pls urgent
PostPosted: September 1st, 2015, 1:21
For Pcb swap you need to match the Pcb number (starting with 100xxxxxx) and swap the ROM
http://www.rescue-it.se
Users browsing this forum: Majestic-12 [Bot] and 73 guests
