 Post subject: Data shows on TV but not in PC
PostPosted: August 31st, 2015, 11:16
Hi, I have two external HDD's both 500 GB with tons of pictures and videos. Both are behaving in the same way. When I plug either of them into my Samsung TV all photos and videos are there, but when I want to see the data in my PC, its not there.
I also tried booting up Linux to see if 'he' can manage to see them, but it just didn't work. Any idea how can I rescue my data?
P.S. I created image using ddrescue (using this guide https://www.data-medics.com/forum/how-t ... -t133.html), seems like there are no bad sectors only malformed FAT table. (its formatted as FAT32)
 Post subject: Re: Data shows on TV but not in PC
PostPosted: September 1st, 2015, 5:56
I would examine the file system with a disc editor, eg DMDE (freeware). Could we see DMDE's Partitions window?
PostPosted: September 1st, 2015, 8:42
If you mean this, then yes. And I can normally see some files when I open it in explorer, but a very large about of data is just not there. (physically yes (i hope) but I cant see it )
PostPosted: September 1st, 2015, 16:03
The problem is that you have a FAT32 volume but the corresponding entry in the partition table in sector 0 has a partition ID of 07, which is NTFS. You need to change this ID to 0C. If you need help with this, upload the contents of sector 0.
PostPosted: September 1st, 2015, 18:12
Great, I've managed to rewrite it. Looks like I have to re-scan entire partition for directories. Any idea on what could cause the the partition ID to be rewritten to NTFS? (I study computer science and I am curious :)
PostPosted: September 1st, 2015, 18:22
I've seen this before, but I don't recall what caused it. I've always assumed it was due to user error. Did Windows ever prompt you to initialise the drive? If so, then that's probably when it happened.
PostPosted: September 2nd, 2015, 8:33
Hard to tell, since those drives were given to me, so I repair them. But I know my uncle used Windows XP.
One more question, now that I searched whole drive for lost directories (it's finished now and I am copying all files to save place), is there a way to add those found directories back to fat table, so I can access them normally (like from explorer)?
PostPosted: September 2nd, 2015, 21:09
I don't know of any way to do this, or whether it is advisable. I would backup the data, rebuild the file system and copy the data back again.
PostPosted: September 3rd, 2015, 1:12
These drives are they WD Passports ?
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: September 3rd, 2015, 4:34
@fzabkar
Ok, thats for your help very much :)
No, one is Adata (USB only powered) - the one I recovered data from. Looks similar thought.
The other one is Seagate, with seperate power adapter - I didnt try this one yet.
Why do you ask?
PostPosted: September 4th, 2015, 6:09
I have seen some cases where WD drives with virtual CD gets corrupted if used on Sammy TVs
Users browsing this forum: Google [Bot] and 101 guests
