 Post subject: MS WORD repair with Batch processing
PostPosted: June 13th, 2015, 4:40
Can someone suggest a professional msword file repair tool with batch processing ?
I have a job of repairing 1500 doc files , I have already tested most of the tools & not satisfied as either they dont give success , 1-2 tools which are giving good results dont have batch processing feature.
Thank You
 Post subject: Re: MS WORD repair with Batch processing
PostPosted: June 13th, 2015, 4:58
I cant help with your question, but I am interested to know the 1-2 tools that are giving good results?
PostPosted: June 13th, 2015, 5:18
Hi PM Sent
PostPosted: June 13th, 2015, 13:28
Did you try to open bad word files in hex editor?
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: June 15th, 2015, 10:03
Can you upload her 3 MSWORD files to see what is the problem.
Maybe helpfull
PostPosted: June 16th, 2015, 5:52
Hi Kum & hhddrec
Thanks for your help. This case is been resolved.
I have got these file a customer for repairs. However Low level diagnostics shows files were truncated , a typical sign of DIY improper recovery.
As per expert in this field - The files appear to have been encapsulated/converted into a container format. Some of the files are having header corruption while in some file data is extended beyond end of file.
I have used almost all commercial tools & have found one of the old tool is more powerful than newer. One not so known developer has been found & his tools are very cheap.
attached are snaps.
WORD file diagnostics.pdf [190.26 KiB]
Downloaded 558 times
PostPosted: June 16th, 2015, 9:21
Good job athena, congratulations!
what tool do you used?
PostPosted: June 17th, 2015, 8:01
Hi hhddrec PM sent.
PostPosted: June 17th, 2015, 10:08
What tool did you used ?
Well done :wink:
PostPosted: June 18th, 2015, 10:51
Hi DRUG
all details sent on PM. Thanks
PostPosted: June 18th, 2015, 11:08
thank you!
PostPosted: September 11th, 2015, 17:05
Hi hhddrec, I would like to know what tool do you use to do it.
Thanks a lot.
Pablo
PostPosted: September 15th, 2015, 13:33
Awesome good job What tool did you used ?
PostPosted: September 15th, 2015, 15:51
It's no wonder the software/developer are not well known, if his customers are unwilling to openly reveal anything about the program or source. Are you under some sort of non-disclosure agreement? Sheesh! :roll:
PostPosted: September 15th, 2015, 15:55
My thoughts exactly. How many PM's are you going to send before you just post the name of the software publicly.
Users browsing this forum: Google [Bot] and 145 guests
