 Post subject: SEAGATE 200GB 7200.9 PROBLEM WITH PCB OR HDA?
PostPosted: September 16th, 2015, 7:00
A friends of mine brought to me suddenly broken hdd as below. No signs or smells of fried components on the PCB. The motor is not starting, but hdd has some strange noise.
Before I start to think about sending it to a pro, I would like to give it a try with swap of PCB.
My questions are:
Which number i have to match with donor: from white sticker 100xxxxxx or from printed reverse on the PCB 100387574?
Should I transfer ROM chip only when firmware is different on donor PCB?
Is there any compatible SATA version of donor PCB?
Thanks in advance for any help!
Recording with noise sounds from HDD:
http://vocaroo.com/i/s0fgFOdsvqz8
 Post subject: Re: SEAGATE 200GB 7200.9 PROBLEM WITH PCB OR HDA?
PostPosted: September 16th, 2015, 7:19
first try to clean contacts
try to match model and fw for donor
probably problem with head stiction
PostPosted: September 16th, 2015, 9:24
Bad Heads.
PostPosted: September 16th, 2015, 13:33
Thanks for reply.
Contacts cleaned, but problem remains :(
Jerovsek, you have written to match model and FW, but I didn't get answer to my question: should I match number from sticker or from printed number on the PCB?
PostPosted: September 16th, 2015, 13:42
Sounds like head stiction to me, new PCB won't fix that.
PostPosted: September 16th, 2015, 17:48
+1
if you insist, you have to match the printed number (and the first part of the sticker number will be matched anyway)
PostPosted: September 17th, 2015, 5:19
Thank you jermy for straightforward answer. :beer:
I am aware that it could be the serious problem with heads, but anyway I would like to try swap PCB. It's not expensive.
PostPosted: September 17th, 2015, 7:17
100% stiction
outsource it
PostPosted: September 17th, 2015, 11:43
Hello demon
When PCB swap you need PCB no and firmware matching
PostPosted: October 2nd, 2015, 15:56
Hi Guys,
I have found proper donor to see if that can help anyway, but as you supposed it didn't. PCB is 100% ok. But at the same time after few attempts the drive suddenly started to spinning again. But that's the end of the good news as it still won't be recognized by the computer. There is still something wrong anyway, something with heads?
Finally, any pro from Poland? I would like to discuss possible price range for this job for my friend before I will outsource it.
PostPosted: October 2nd, 2015, 16:28
You can contact member Arvika, he's in Poland:
memberlist.php?mode=viewprofile&u=14062
http://www.rescue-it.se
PostPosted: October 5th, 2015, 4:17
Thx mr_spokk :)
PostPosted: October 5th, 2015, 5:23
Damon wrote:
But at the same time after few attempts the drive suddenly started to spinning again. But that's the end of the good news as it still won't be recognized by the computer. There is still something wrong anyway, something with heads?.
Ouch, this is why you don't want to replace PCB for a stiction problem. It looks like it has broke free, but possibly ripping heads off or damaging them in the process. Any further spinning is likely causing much more damage and it could have made an easy job very difficult.
