Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: Apple Fusion Recovery / Rebuild
PostPosted: September 17th, 2015, 13:03
To recover the data you could probably do this on a Windows pc. Yea I know it goes against the grain but hey if it works. I would use a newer version of R-studio and mount those images as a volume set. Then scan the volume. If all goes well you should see the hfs+ partitions, the folders and the files.
PostPosted: September 17th, 2015, 13:16
I did actually try this but wasn't sure of the parameters to set for R-Studio. It's my understanding that although the Fusion volume operates similar to JBOD it cannot be rebuilt using standard JBOD parameters. Plus I think the Windows Bootcamp partition would throw off proper detect of the volume.
PostPosted: September 17th, 2015, 13:50
Here I would use a PC not a Mac running Bootcamp.
Not sure of the parameters but the R-studio support should know if this is possible. Might be worth asking?
PostPosted: September 17th, 2015, 14:08
Also Diskwarrior will support Fusion drives and might be a useful tool for recovery. Then after it can be used to attempt a repair.
PostPosted: September 17th, 2015, 16:22
Yes, I've check with Disk Warrior - no dice, when volumes are connect separately it doesn't detect it as a Fusion vol, when both are install in iMac system crashes immediately when iMac is connected via target disk mode or if you try to boot off USB so that is a no-go. I'm afraid volume is simply FUBARed.
PostPosted: September 23rd, 2015, 8:43
I ended up using thunderbolt target disk mode and creating a 3.12TB R-studio image from the other connected mac. R-studio sees it as a Volume
Saves taking it to bits if drives are ok
I didn't do this on mine,but if you connect it via Target disk mode with the drives in the original positions and run Disk Warrior / Disk Utility on the Mounted volume you could get the thing to boot again if its just a wonky OS/X problem.
andy
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
PostPosted: September 30th, 2015, 17:06
Can't do anything with target disk mode as it immediately prompts a kernel panic and spontaneous reboot if connected to another 10.8+ Mac via Thunderbolt. That is it goes into target disk mode but the moment you connect that cable to another Macbook / iMac the working system crashes and reboots, this happens regardless of whether it is booted into the OS, running off recovery volume, or booted off DiskWarrior 5 USB recovery volume.
Users browsing this forum: Protech and 245 guests
