 Post subject: ST3000DM001 Barracuda 7200.14 FAIL Servo Op=0100 Resp=0003
PostPosted: September 21st, 2015, 3:34
Dear all,
I have tried looking for this error but couldn't find anything in here. If this already has been answered I am sorry for my double post.
Lets start with this: the drive was sused for non-vital storage. My important stuff is on a 4-disk zfs raid-z array, so some kind of n+1 redundancy. However, I would like to access this failed drive once more to get the data off and into my array (increase its capacity recently).
Problem: drive spins up, hear heads moving, spins down. BIOS not detecting/reports as 4.1GB
After looking at this and other boards I bought a USB CP2102 adapter and connected to drive.
It spins up, and give following errors after it spins down again. No input (CTRL+z) possible.
0x40M
Spin Up
FAIL Servo Op=0100 Resp=0007
0100 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 18C0 004B 03B4 4480 0008 0000 0000 0000 0D32 0000 0000 0000 0000 0000 0000 0000 CEB1 3309 FFFF 2000 DD5B 0002 0000 3FC3 0000 3FC3 0000 2247 0000 0020 001A 0007 0000
ResponseFrame 2140 004E 03B4 4480 0008 0000 0000 0000 0D32 0000 0000 0000 0000 0000 0000 0000 CEB1 3309 FFFF 2000 DD5B 0002 0000 3FC3 0000 3FC3 0000 007F 0004 0020 001A 0004 0000
I tried isolating the spindle or the (I hope that is the right name for it) the HDA connector. Still gives the FAIL Servo etc.
Interesting for me is, that even if I completly dismount the PCB and boot it still gives the same error.
What puzzles me, if it is an "internal" problem (like heads) why does it still give this error if the PCB is completly isolated from the HDD?
Also, I cleaned the contacts on the PCB that go to the spindle and HDD as I read some 7200.14 got problems with it. It seemed there was some dirt or similar. Contacts are shiny again, but didnt help.
I would greatly appreciated any help!
Greetings from Germany.
 Post subject: Re: ST3000DM001 Barracuda 7200.14 FAIL Servo Op=0100 Resp=0
PostPosted: September 21st, 2015, 11:17
Sounds like, a bad heads.
Head can't find servo information on platter. Not DIY. Sorry.
PostPosted: September 21st, 2015, 11:21
Thanks. But why is the same error even if PCB is isolated from HDD?
If the heads are bad only solution is head replacement, right? Any 7200.14 head or only from 3 TB versions?
PostPosted: September 21st, 2015, 11:42
i wouldn't advise you replacing heads without experience, especially on DaMn series (you risking the data, and can cause permanent loss), but it's up to you (it's your data you can do whatever you want)
PostPosted: September 21st, 2015, 11:58
Thanks for all the replies.
Well, the data is not that important, hence paying for recovery is no option
And some learning can't harm.
But why is it the same error of the PCB is isolated?
Which heads should fit?
PostPosted: September 21st, 2015, 14:11
Because the heads are considered as "failing" in both modes as a "passing" signal was not received. It is just code. Does not know how to diferentiate. It's kind of being asked verbally what your name is. You will answer the same with your eyes open or covered.
PostPosted: September 21st, 2015, 14:42
Ah ok. So somewhere in non-volatile memory they are marked as bad until the board receives a different signal.
Got it.
Never gonna buy Seagate again. This was actually a RMA drive. Which failed like 1 month after guarantee expired. First SMART showed I/O errors. Support said that's only a firmware problem. So I updated. Shortly later this happened.
PostPosted: September 21st, 2015, 16:12
No. There is some testing done on every power on, so the drive is programmed to test the heads and see if they respond. If they don't respond as expected, then it spits the message you see. Very similar to fault codes on a car with the OBD system. Every time you turn the engine ignition on, some tests take place on the fly. If there are issues, you get messages on the digital display and/or lights pop up (service engine light for example) on the dashboard.
PostPosted: September 21st, 2015, 21:47
A very wise decision. :mrgreen:
Users browsing this forum: Google [Bot] and 41 guests
