 Post subject: st1000DM003 again !
PostPosted: September 19th, 2015, 4:09
Greetings friends ,
this is now the third case i have , same model , same family , same symptoms
using ddi4 , drive ID ok , after 15 secs lag ..
log is :
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
TCC:0020
(P) SATA Reset
ASCII Diag mode
F3 T>
Family : LUXORLPLUS_2_0( 203)(FF-FF-FF-F
Admin : GPG17B.CCD4.AAAL00.CC47
Firmware : CC47
Speed : 7199 RPM
Head : 2
Capacity : 244923212 (125G)
S/N : Z1D4JRWD
F3 T>
lists are
F3 T>V4
V4
Reassigned Sectors List Enabled
Entries: 0000, Alts: 0000, Removed: 4013,
Pending: 0000 Host Pending: 0000
Idx LBA PBA LLLCHS of LBA Wdg PLPCHS of PBA SFI Hours Msecs Status BBM Mask
NRG list has 0 enteries
F3 T>V2
System Slip Defect List
log log log phys phys
LBA span cumm cyl hd sctr zn cyl sctr SFI
0 0 0 0 0 0 0 380C2 0 FFFFFFFF 0
62B42 151BE 151BE 0 1 0 1 33E0B 0 FFFFFFFF 77D00
C5684 151BE 2A37C 1B0 0 0 2 38272 0 FFFFFFFF EFA00
1281C6 151BE 3F53A 1B0 1 0 3 33FBB 0 FFFFFFFF 167700
Head 0: entries 2 slips 151BE
Head 1: entries 2 slips 2A37C
Total Entries 4 Total Slips 3F53A
while imaging , something wrong is obvious , drive images like 1000-1500 LBAs then power-reset as it will stuck and ddi will initiate this command ..
heads test fine ..
i cleared alt-list , and smart , and reconstructed the translator , same behaviour :(
could be platter damage ?
 Post subject: Re: st1000DM003 again !
PostPosted: September 19th, 2015, 5:13
i would say weak heads, can you show us the resistance of both heads ?
Data Recovery Pakistan
PostPosted: September 20th, 2015, 15:02
Hi again ,
nop , heads resistance is extremly fine , i have seen more resistance value on the same family , with no reading/writing problems ..
seems like some list is overloaded , and causing this kind of slowliness , what do you think ?
PostPosted: September 22nd, 2015, 6:01
i still vote for weak head/s.
did you try selective head imaging and see which head can read fine throughout the surface. i can tell you from my experience on the same drive where both head test was fine even both heads can read fine from start LBA but after a certain LBA head 1 did't read well.
after head swap i was able to image the drive 100%. :)
PostPosted: September 23rd, 2015, 2:09
I had one last week that cloned fine up to about 71% then really really struggled, new heads and bingo! Imaged 99.9% :-)
Users browsing this forum: No registered users and 91 guests
