 Post subject: Dead hitachi HDS721010CLA332. Will a direct PCB swop work?
PostPosted: October 2nd, 2015, 7:37
I have a hitachi HDS721010CLA332 1tb drive that stopped working. It was not detected by windows 7 at all; the BIOS did not display it either.
I had another hitachi drive of the exact same specs and swopped the boards, and the drive was detected in BIOS and in Windows. But in Windows it only showed up in the drive management screen, and said it was uninitialized. I haven't initialized it yet, but I suspect once I do no files will be seen.
Can I know if this business about swopping Nvram on the boards also applies for the Hitachi HDS721010CLA332? Even if both donor and receipient boards have the same specs and firmware (3EA) already?
Where is the nvram chip anyway?
 Post subject: Re: Dead hitachi HDS721010CLA332. Will a direct PCB swop wor
PostPosted: October 2nd, 2015, 9:07
you need to move the NVram over. Post a pic and we can show you the ROM information. But I have a feeling the problem is somewhere else. Very rarely I have seen this family have board issues.
PostPosted: October 2nd, 2015, 9:10
What makes you think it is a PCB problem?
PostPosted: October 2nd, 2015, 9:15
Here is a pic.
PostPosted: October 2nd, 2015, 9:16
Because with the original PCB, the PC just got stuck at the bootup POST. in the BIOS the drive wasn't detected and shown as a possible boot drive.
After I swopped the PCB with another one, these worked, just that I can't see the data.
PostPosted: October 2nd, 2015, 9:35
Does the drive spin with the original PCB on? Furthermore, why do you think it failed? Did you notice something happen prior to failure?
PostPosted: October 2nd, 2015, 9:44
How can i test if the drive spins without opening it? Anyway the failure to spin up was intermittent until recently. Usually whenever I failed I rebooted 2-3 times and it worked but now that doesn't solve it anymore.
PostPosted: October 2nd, 2015, 9:46
Through listening and touch. You will hear internal components gently making sounds. Also it emits a slight vibration.
These should indicate spinning.
Yeah, if it worked once every 2-3 reboots, then more than likely it is not a PCB issue. Likely the problem is firmware and/or mechanical related. Problem is, all these rebooting attempts really have been exposing the disks to further damage. Not good.
PostPosted: October 2nd, 2015, 10:14
Okay, i tried again. I have no idea if it's spinning up with either pcb installed.
but with the original pcb, i get stuch at the bootup screen and windows doesn't even load. Bios cannot find the drive at all.
Without any way to access the drive I can't investigate further.
Swopped the pcb alone, without the nvram, and I can boot into windows. Using a hard drive utility to view the uninitialized drive gives strange results. Other drives return things like [SEAGATE, 4TB], while this drive returns [ , ]. Like it cannot see the drive firmware.
PostPosted: October 2nd, 2015, 10:26
Right, it makes sense, because, as is, the donor PCB is not fully compatible with your drive.
By the way, swapping PCBs on Hitachi drives like that could in theory cause further firmware damage. rarely, but sometimes it could happen. It has to do with how Hitachi designed their drives with regard to firmware. Should test only by ensuring firmware is compatible through methods already suggested in previous posts with regard to NV-RAM or by ensuring firmware does not actually get activated while testing.
PostPosted: October 2nd, 2015, 10:39
Both are using the same 3EA firmware. Is the nvram the same as firmware?
PostPosted: October 2nd, 2015, 10:51
NV-RAM is a firmware component. Firmware is made of several components.
PostPosted: October 6th, 2015, 4:00
Sounds to me as if the original HDD's BIOS ROM would have to be "swopped" as well :twisted:
PostPosted: October 6th, 2015, 5:51
is there any way to backup the rom before transplanting?
PostPosted: October 6th, 2015, 6:37
yes, using a programmer
PostPosted: October 7th, 2015, 22:38
Can I know for this hitachi drive, when is the NVram with the head info written to? Is it only at the factory, or is it done whenever you format the drive?
reason is because I have another drive of the same firmware version, model number and batch number. I was wondering if this pcb swop would work, or do I really need to swop the nvram chip?
PostPosted: October 7th, 2015, 22:54
yes
no
you really have to swap the NVRAM (or it's content)
Users browsing this forum: Google [Bot] and 203 guests
