 Post subject: Burnt Seagate SATA PCB
PostPosted: October 4th, 2015, 23:01
Hello there everyone.
Im newbie, a new member here on hddguru forum.
I would like to ask about my Seagate Expansion Drive 1TB 3.5" problem.
I'm using this hard drive rarely just about a couple hours in a week and there is no problem with the disk itself. I've checked with HDD Sentinel when the hard drive is still running, and I found performance and healthy is on 100%.
The problem is when my brother used it for watching movies through the hard drive about two hours, the hard drive stopped working. Maybe the hard drive itself was hot enough to burnt the pcb. He was putting the hard drive on a carpet, i thought it doesnt have enough air circulation so becoming so hot and exploding the pcb.
And now, my harddrive is not spinning at all. My first thought is maybe the enclosure is the problem. so i open the enclosure and i put it on my PC through SATA port. But it still doesnt spinning. So, i dissasembly the sata pcb on the hard drive and i found one of the chip was burnt.
here is the picture
The question is
Is there anyway to fix the pcb with burnt chip like that??
I know to fix the hard drive is to replace the pcb itself, but i doubt if there any pcb like that to replace on my hard drive since i live on a remote city with lack of electronic things.
if im gonna buy it, where can i find it and what price range for that pcb? thank you very much.
File comment: the picture with burnt chip.
File comment: PCB picture from abouve
 Post subject: Re: Burnt Seagate SATA PCB
PostPosted: October 5th, 2015, 0:00
The failed chip is the motor controller. It looks like the TVS diodes might be OK (the series inductors are not burnt), so I would check the resistances between the 3 motor terminals. If they are OK, you would be best advised to replace the PCB and transfer the "ROM" chip (25FU406B). Some PCB suppliers (eg hdd-parts.com) will do all this for US$50.
PostPosted: October 5th, 2015, 3:09
is it possible if i just replace the pcb from the exact same model of the hard drive? i'll search the local store for broken hard drive with the same model.
it will be a hard thing to do if it is required to replace the ROM chip and I dont think there are any local technician could do the job since i live on remote town.
so, it is clearly impossible if somehow do something to the pcb and will make it work??
maybe like resoldering or anything else. because there was nothing wrong the way i'm using the hard drive (not mistaking any adapter etc) and i thought it just an air circulation problem that make the hard drive a little hot and burn the chip.
Thank you for any suggestion. :D
PostPosted: October 5th, 2015, 14:10
Swapping the "ROM" chip is mandatory on 7200.11 and up Seagates.
PostPosted: October 5th, 2015, 22:08
To replace the PCB you have to match the Firmware of the old one to the new one. Either you have to get a board from an exact existing drive or you can send it off to a service which will match the board and copy the firmware for you. For a fee. fzabkar is the expert in this field and whatever he says is usually the best idea.
PostPosted: October 6th, 2015, 2:16
Really? So now does the drive work with a PCB that has the s/n of the other drive programmed into the "ROM"?
With older drives (7200.10 and below) then yes you could get lucky in doing what you suggest (getting exact same firmware board), but newer F3 architecture drives the info in the "ROM" is totally 100% unique.
PostPosted: October 6th, 2015, 19:18
Seagate drives store their firmware in two places. A small portion resides in serial flash memory (aka "ROM") on the PCB while the majority is stored in a reserved System Area (SA) on the platters. When replacing the PCB, the firmware code in the ROM must be compatible with the firmware in the SA. Model series up to and including 7200.10 simply required matching the firmware between patient and donor PCBs.
Starting with the 7200.11 model series, Seagate HDDs incorporate F3 firmware architecture. F3 ROMs consist of several code and data sections. As before, the code sections need to be compatible with the SA. However, the data sections are unique to each drive. There are several "adaptive" modules which contain calibration data, including SAP (Servo Adaptive Parameters), RAP (Read Adaptive Parameters), and CAP (Controller Adaptive Parameters). It is very unlikely that two drives will have SAP and RAP adaptives that are similar enough for a direct PCB swap to work. In any case the CAP module contains the drive's serial number, so a straight swap will never work.
To understand the reason for the RAP and SAP data, see the following article:
http://hddscan.com/doc/HDD_Tracks_and_Zones.html
PostPosted: October 6th, 2015, 20:51
I would say be very carefull about sending your patient pcb anywhere for rom replacement. If it is lost, recovering that rom is an immense work, and there are not many people able to do that worldwide.
PostPosted: November 9th, 2025, 18:01
Hello guys, first of all thanks a lot for the great information shared here, which makes me asked this question even though I am aware that the Thread is 10 years old by now:
I have a Seagate Barracuda 7200.10 which was plugged into a wrong powersupply while in a external housing. I already established that the 13V TVS is burned and suspect the 5V 0Ohm Resistor to be destroyed as well, although I am not sure if I am looking at the right thing for the latter.
However, I have the chance to buy an identical model (same sticker number on the PCB) drive for 15€, which made me think about soldering the RAM of the damaged one onto the new pcb, just to be sure I dont fry anything else with a pcb that is potentially faulty in other components.
Now I read that up to 7200.10 an exchange of the ROM might not even be necessary. Can I just change the PCB, see if it works and then change the ROM in case it does not, or do I risk destroying anything if I do that?
Any help is greatly appreciated.
BR
Minucrest
PostPosted: November 10th, 2025, 10:44
There's a high risk of damage to the preamplifier chip inside the hermetic block.
The ROM on the 7200.10 is not unique, but may differ in firmware version. Everything is checked via a terminal. USB-TTL 9600 8N1.
PostPosted: November 25th, 2025, 5:17
Hello, I had a similar case, where motor controller was fried. you can find it here in this forum.
And replacing the controller chip brought pcb back to life. but your diy skills must be at the pretty high level.
PCB swap alone will not bring hdd back to fully working order as you already know.
wish you Good luck with the repairs!
Users browsing this forum: Google [Bot] and 61 guests
