 Post subject: HELP.....Almost saved Seagate Barracuda 2TB.....
PostPosted: October 7th, 2015, 8:21
Hi All,
New to the forum.....so, long story short, I did something to the power supply of a Barracuda 2TB external drive.....after a lot of research, I was able to buy a used circuit board with the same F/W etc......last night I swapped the ROM chip and VOILA....she spun up and my computer recognized it (in the docking station). At first, it came up just like it always did, I could see all of the folders/files, etc. (even with a little clicking). I was going to try to copy over some files before I junk it because I know it's on borrowed time. I unmounted it from the dock.....looked at another drive, then put it back in and now it is only being recognized as an un-formated drive!!! No more files showing etc. It is at least being recognized.....
WHAT should I do now? I've tried testdisk and it ran all night just coming back with read errors and not a single percentage of completion.
Thoughts? Comments? Suggestions?? Anyone???
Thanks guys and gals!
Rob
 Post subject: Re: HELP.....Almost saved Seagate Barracuda 2TB.....
PostPosted: October 7th, 2015, 8:47
Stop using any recovery software like testdisk, you are just killing off your drive. Your only chance is trying to take an image off the drive with ddrescue.
PostPosted: October 7th, 2015, 8:50
The heads are probably starting to crash...the more you do, the worse it is going to get. Running testdisk overnight was not a good idea. Anyway, I suggest you take it do a data recovery pro.
PostPosted: October 7th, 2015, 8:57
The data really isn't THAT important to warrant spending money to send it off for recovery....I wanted to try and do what I could myself just for the satisfaction. I will try doing an image with DDRescue and see what that does. Thanks for the ideas everyone.
Rob
Users browsing this forum: No registered users and 34 guests
