 Post subject: Hitachi HDS721010CLA332 reads first ~5M sectors only
PostPosted: October 2nd, 2015, 5:06
Hello
I had this drive (Hitachi HDS721010CLA332) with faulty read/write heads. The heads have been transplanted with an exact donor (clean air room of course). Using PC3000 had difficulties reading the drive ID but going around it I managed to get it. The drive read only the first approximately 5 million sectors only then stopped reading. While the drive is still calibrating, the heads are fine. I have checked the drive modules and all the important ones are okay.
Has anyone else had this problem before?
Thanks in advance
 Post subject: Re: Hitachi HDS721010CLA332 reads first ~5M sectors only
PostPosted: October 2nd, 2015, 16:22
Could still be weak heads, SA tracks a wider than user tracks, thats why you can read. Try to read through utility in DE.
http://www.rescue-it.se
PostPosted: October 2nd, 2015, 23:14
Could be a PSHT issue (Plist). Tried reading both copies separately and see if any have errors. PC3000 will sometimes just fill in bad areas with zeros to get a working one but this could cause some areas not to line up so you can't read.
PostPosted: October 6th, 2015, 4:33
Thank you for the replies, but the heads have been transplanted from a brand new drive so definitely they are fine.
With Hitachis, I am aware that the PList is very sensitive to damage, but this one is perfectly fine.
I'm still a bit stuck here... Hitachis are all awkward :roll:
PostPosted: October 6th, 2015, 5:05
I think I cracked it...
First I tried to use the P-List from NV-RAM, but it said it could not find it. Then I copied the P-List from the NV-RAM to the service area and it started working!
Thanks again for your help!
PostPosted: October 6th, 2015, 6:08
Does the drive ID perfectly fine in PC3K, or do you have to "kick start" it with the PC3K Hitachi ARM utility?
PostPosted: October 6th, 2015, 20:35
:roll:
i might be missing something here...
PostPosted: October 7th, 2015, 11:02
:roll:
Respected Pepe Sir ,
Exactly i had the same question .BS The NVRAM Does Not Have Plist
PostPosted: October 7th, 2015, 19:56
yeah, not what i know of...
Users browsing this forum: Google [Bot] and 207 guests
