 Post subject: WD Elements
PostPosted: October 12th, 2015, 0:27
hi,
I received WD element external hard drive (product of Thailand). i would like to know if it has encryption on it.
thanks & best regards,
 Post subject: Re: WD Elements
PostPosted: October 12th, 2015, 1:04
WD elements HDD are not encrypted
PostPosted: October 12th, 2015, 1:09
+1,,,,,
Expect, the Unexpected
PostPosted: October 12th, 2015, 2:02
thanks for all your answers.
PostPosted: October 12th, 2015, 22:34
I beg to differ, it depends on the generation of the product. I recently bought a WD Elements 5TB and took the 5TB Green drive out of the case, when connected to SATA bus it shows RAW partition. When I connect a backup spare HDD to the Elements SATA-USB3 board it shows RAW as well. I suppose it does have encryption for the new Elements. The SATA-USB3 bridge chip is ASMedia AS1051W.
The un-encrypted seems to be the old generation horizontal enclosure without vents. Mine is a vertical enclosure with vents, looks like "MyBook" but a bit simpler.
https://images.duckduckgo.com/iu/?u=htt ... 54.jpg&f=1
PostPosted: October 12th, 2015, 22:49
Was meant to add a picture but it's been put to moderation list.
What I was going to say was the new Elements with vertical enclosure and vent holes like MyBook's seems to be encrypted as well. I bought a 5TB Elements, took it apart and discovered that data on the HDD is encrypted. The bridge chip is Asmedia AS1051W
Users browsing this forum: No registered users and 264 guests
