 Post subject: No TVS Diode on old hard drives (IDE)
PostPosted: October 16th, 2015, 6:11
Hi
I have a hard drive that does not power on.
There is power coming in. I know I can replace the whole PCB but I was wondering is there anything similar to the TVS diode I can check.
All I see on the PCB are lots of capacitors and a couple of transistors
I have looked at a few old hard drives mainly IDE and cannot find any diodes on them.
I hope some one can advise.
Thanks in advance
 Post subject: Re: No TVS Diode on old hard drives (IDE)
PostPosted: October 16th, 2015, 6:21
post a good quality picture of the PCB would be my advice to start with.
PostPosted: October 16th, 2015, 6:54
yes, post picture so someone can point you to the right direction.
RAID/Server Recovery
PostPosted: October 16th, 2015, 7:16
I have attached photos that I have got through google images
I have two drives that do not have tvs diodes
deskstar 40gb and maxtor maxline ii 320 gb
PostPosted: October 16th, 2015, 7:48
Sorry forgot to attach photos of the Maxtor pcb. I will do that shortly
Can anyone help with the Hitachi pcb please
I can't see any diodes or fuses. Just transistors and capacitors.
PostPosted: October 16th, 2015, 9:34
any reason you cant post photos of your actual boards? those pictures really don't come up big enough. for example, pictures in this post are good(for reference) http://forum.hddguru.com/viewtopic.php?f=1&t=32050
fuses or fusible links can be labelled on silkscreen of pcb with component numbers starting with L, resistors with a "0" on them and components labelled with an "F" are all things that may be worth looking for(test continuity).
PostPosted: October 16th, 2015, 10:16
Thanks for the help
I cannot find any fuses or fusible links
I have uploaded some better images
I do not have access to a camera at the moment
can some one advise on what points to test or to determine which components are faulty please
PostPosted: October 16th, 2015, 10:50
Hi
attached is image of the maxtor drive
when plugged in has power but doesnt spin up but used to
no diodes
