 Post subject: how to connect to terminal
PostPosted: October 30th, 2015, 11:12
hot to connect with terminal
 Post subject: Re: how to connect to terminal
PostPosted: October 30th, 2015, 11:13
bsy error
PostPosted: October 31st, 2015, 17:45
The 7200.11 BSY error fix is does not works on 7200.14 drives.
About terminal connections: Use two pins that nearest to SATA connectorand use 38400 kbps connection.
PostPosted: November 1st, 2015, 1:49
i connect but there is no response in it
PostPosted: November 1st, 2015, 2:18
if there nothing in the terminal log when you power on the the drive, then something is wrong with settings and or with the wiring
PostPosted: November 1st, 2015, 3:45
another hard disk(500gb) connected but 2tb is not connected
PostPosted: November 1st, 2015, 6:06
its not show in bios
PostPosted: November 1st, 2015, 8:51
yes i need data
PostPosted: November 1st, 2015, 9:52
the drive spins at all ? do you hear any unusual noise, clicking, clunking, beeping Etc. ?
PostPosted: November 3rd, 2015, 9:09
there is no noise like head damage
Users browsing this forum: No registered users and 67 guests
