 Post subject: Seagate 7200.11 unknown parameter and IO error
PostPosted: November 1st, 2015, 7:28
Hello guys,
thank you for any help.
So my hdd Seagate 7200.11 1 TB died recently and i admit i must have screwed it up.
Now im using a UART connection to repair/refurbish it.
Let's assume that data is not important.
What could be the best way to proceed? I dont want to spend money on it possibly.
 Post subject: Re: Seagate 7200.11 unknown parameter and IO error
PostPosted: November 1st, 2015, 8:25
Some actual details of what you did that "screwed the drive up" would be helpful.
PostPosted: November 1st, 2015, 8:31
I pretty much tried every single command,
1.I cleared the smart (N1, i4,1,22)
2.Spin up and down works
3.I followed the LBA0 guide (not BSY since when i use the paper to isolate the chip i can't communicate it seems)
4.I then used the hard format m0,8 .... but at 3% i receive bad sectors errors everywhere
My firmware is still CC1H and not SBD15 or similar
HDDGuru Low level format tool gives I/O error 1117
I haven't tried mhhd yet
I think that everything has been generated by HDD Generator, i think it screwed everything up when i tried to repair sectors since the hdd was really unresponsive with lots of dead time (stuck at 100% usage)
PostPosted: November 1st, 2015, 9:16
So is the constant read error associated with a broken drive's heads?
That's strange because some sectors are read correctly
PostPosted: November 1st, 2015, 9:33
HDD Regenerator = HDD Destroyer. It's not for data recovery, even their own disclaimer says that. It's for refurbishing drives with a few bad sectors. Drive is toast, toss it.
PostPosted: November 1st, 2015, 9:46
Ok so last question, could you link me an explanation about the structure of the low level sw (in general), like what is F3>/1 /2, the overall design behind an HDD.. Is the F3 Arch a standard?
Thank you for your help,
Users browsing this forum: Google [Bot] and 66 guests
