 Post subject: Hitachi FW problem _ help to fix it
PostPosted: November 3rd, 2015, 9:24
Hitachi HTS547564A9E384 640GB has a problem in FW
Some of FW has checksum error:
AVZN
CGDF
HLR1
HLR2
AMPM
SDM1
and one failed:
DMP1
Did any of these FW are important for DR
If I replaced them from SA-C or from another HDD, the data remain or gone!
Does any member face such this problem?
Expect, the Unexpected
 Post subject: Re: Hitachi FW problem _ help to fix it
PostPosted: November 3rd, 2015, 12:33
whats the initial problem ?
is it for DR ?
PostPosted: November 3rd, 2015, 13:14
Yes for DR purpose
Its come from clint like that
PostPosted: November 3rd, 2015, 13:23
do you have access to user data ?
PostPosted: November 3rd, 2015, 13:28
No, I didn't access to user data
I tried to access to user data by DC
But I con't becuase the problem in FW
PostPosted: November 3rd, 2015, 13:46
i don't think that those mod's are your problem (maybe CGDF) i just checked on a healthy HTS547550A9E384 drive and all of those mod's are problematic except for CGDF
PostPosted: November 5th, 2015, 1:45
it's very important mention, I have the same HDD specs and healthy, When I checked it, give me the same result
and read mod "CGDF" correctly.
When I see the content of two mod's, I found alot of different
and I check if I can write to this mod in patient HDD, I seccessed
I attament the content of two mod's to check them!
CGDF for Good HDD.rar [333 Bytes]
Downloaded 1739 times
Err_CGDF for patient HDD.rar [3.24 KiB]
Downloaded 1733 times
PostPosted: November 5th, 2015, 5:31
problem solved ?
PostPosted: November 5th, 2015, 6:10
jermy wrote:
problem solved ?
No, the problem doesn't solved for now.
I mean "I seccessed" to make write test to CGDF mod
Now, what the important of this mod, and If I replaced it with donor, Are that effect to data?
PostPosted: November 5th, 2015, 7:52
i filled up this mod with 0x00 and didn't affect user data
PostPosted: November 11th, 2015, 2:33
After many trials on DC, I accessed to user data
now I image from HDD but it has alot of bad sector
Wt I can do to minimize the bad sector to recover almost user data?
PostPosted: November 11th, 2015, 13:27
I think like that, but this step is final step after image as possible as data
PostPosted: November 12th, 2015, 2:56
DC already do that
closed case :D , I recovered client data from image :)
Thank you very much for ur thoughts
I'm really appreciate that.
Users browsing this forum: No registered users and 14 guests
