 Post subject: SAMSUNG LED 2A01
PostPosted: November 3rd, 2015, 13:31
I got from a client SAMSUNG hard drive HN-M101MBB/AV1
When I conected it to the PC3K the drive didn't spin at all and didn't make any sound.
In the terminal I got error:
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
And so on..
When I checked about the error I found that it means that the PCB is not native.
I told that to the client and he admint that the drive was in other lab. The other lab admited that they "mistakenly" gave the wrong PCB to the client. They agree to send us the "so called" original PCB.
I got the "original" pcb from the other lab and swap bwtween the PCB and the "original" pcb but again the same error message in terminal as above (LED 2A01)..
The hard drive doesn't spin and doesn't make any sound even with the "original" PCB.
So, do you think that the "original" pcb is again not the native onel?
or the error doesn't indicate that the pcb is not native?
As it seems the drive wasn't open at the other lab.
 Post subject: Re: SAMSUNG LED 2A01
PostPosted: November 3rd, 2015, 13:33
This is the full terminal log:
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
DDR size detected = 16MB
>>>Invalid PA VID
*PA VID=0011 PN=0000 Rev=0000 Invalid Preamp
>>>Invalid PA VID
U
S_0PreampError
EPOK
UDed
PK_4 C: 0 H:0
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
Active‏
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer :א
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
>>>Invalid PA VID
>>>Invalid PA VID
U
S_0PreampError
EPOK
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
>>>Invalid PA VID
>>>Invalid PA VID
U
S_0PreampError
EPOK
UDed
PK_4 C: 0 H:0
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
>>>Invalid PA VID
>>>Invalid PA VID
U
S_0PreampError
EPOK
UDed
PK_4 C: 0 H:0
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
LED 2A01
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer 
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveF׳
ActiveFW : 00
FWVer : 000‎
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FWVer : 0001
ActiveFW : 00
FW
ActiveFW : 00
PostPosted: November 3rd, 2015, 15:14
Probably bad preamp.
PostPosted: November 3rd, 2015, 16:58
Is there an "Invalid PA VID" or "Invalid Preamp" or "PreampError" message?
viewtopic.php?f=1&t=31226
Does the error output change if you isolate the HDA contacts?
Can you tell us the markings on the ICs? We could then compare the date codes on the ICs against the manufacture date on the label. That should help us to determine whether either PCB is native.
PostPosted: November 29th, 2017, 10:30
same message.. hdd doesn't spin up with original Pcb.
same pcb spins the motor but it useless.... no data can seem.
rom swap also useless. it doesn't spin...
is that rom fault or pcb or preamp?
>>>Invalid PA VID
*PA VID=0006 PN=0000 Rev=
000F Invalid Preamp
U
S_0SHOS-(2BA2g8zP.d79)
* Enable Buffered RW Mode
* MAXIMUM_LBA = 000072D3
ENG>@
[RESET:1 00000000:00000060:00070000]
[LINK:0133]
[RESET:1 00000000:00000064:00070000]
[LINK:0133]
[E:0000]
[E:0000]
[E:0000]
[E:0000]
[E:0000]
[E:0000]
[E:0000]
PostPosted: November 29th, 2017, 11:07
if i isolate the hda contact nothing changes...
>>>Invalid PA
VID
*PA VID=0006 PN=0055 Rev=0000 Invalid Preamp
U
ENG>@
[RESET:1 00000000:00000067:00070000]
[LINK:0133]
[RESET:1 00000000:0000006B:00070000]
[LINK:0133]
[E:0000]
[E:0000]
[E:0000]
[E:0000]
[E:0000]
[E:0000]
[E:0000]
Users browsing this forum: No registered users and 80 guests
