Joined: February 12th, 2014, 1:33 Posts: 48 Location: INDIA
WD 500 GB
After Head Replacement from Exact Donar in clean room gives following error in PC3k
Techno mode key Techno mode key......................... : Ok RAM: HDD Info reading........................ : Ok Heads number............................ : 1 Cyl Count............................... : 256 Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "SCT INVALID FUNCTION CODE" ROM: ROM reading............................. : Ok ROM Data size........................... : 192 Kb ROM version............................. : 03.36B ROM generation.......................... : 03.55B Link table version...................... : 05.02. Consolidated ROM version................ : 00030036 ROM Modules: Flash ROM dir reading................... : Ok (Active) Flash ROM dir reading (Ext)............. : Ok Modules directory address............... : 74 084 SA regions address...................... : by default SA Translator loading................... : Ok Heads configuration..................... : by map Heads number............................ : 2 Heads number in use..................... : 2 Switched off heads...................... : No Heads map............................... : 0,1 ROM Firmware version.................... : 00030036 Service area: Permanent overlay....................... : Not loaded SA dir reading (ID)..................... : FM ERR HEADER II SIGNATURE INVALID SA dir reading (ABA/CHS)................ : Ok SA Access............................... : NONE Configuration reading................... : Module 02 not found SA structure test Heads test Cylinder to test........................ : -10 Heads to test........................... : 0 Head 0.................................. : Ok 11 Module not loaded , I have loaded from Resource .
Is this error related to Micro jog ?
Please help.
Peter
| Attachments: |
