Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: HDD recovery when the PCB is OK
PostPosted: November 16th, 2015, 13:28
А надо хватать? Драйвов почитай уже почти не осталось.
PostPosted: November 16th, 2015, 13:30
jadew, before changing heads - try to read system modules first.
PostPosted: November 16th, 2015, 18:15
I still have
+ I just wonder these discs.
+ and admire the architecture code density (compared to the monstrous ARM)
PostPosted: November 16th, 2015, 18:53
What are you looking for? Is there left any interesting things?
PostPosted: November 16th, 2015, 19:04
I would like to deal with the super-cmd's of the loader and in particular the FSW
PostPosted: November 16th, 2015, 19:25
Are there any other mitsi processors that have similar core but more open tools? you might find some references or even utilities
PostPosted: November 16th, 2015, 19:38
2013 was around the time when Hitachi and Mitsubishi merged their semiconductor businesses into Renesas. It might be worth downloading the short form catalogues of around that time to see what kind of processors were available to the general market.
PostPosted: November 16th, 2015, 20:13
I tried to look for it. but for such a search need good English,which I have no :)
PostPosted: November 16th, 2015, 20:40
I believe you have those CMDs, right?
I used to use them 7-8 years ago, but didn't find real benefits from them.
PostPosted: November 16th, 2015, 21:03
Here are the 16-bit and 32-bit micros that were around at the end of 2012:
16-Bit Microcontrollers :
http://web.archive.org/web/200212160844 ... ION=Global
32-Bit Microcontrollers :
http://web.archive.org/web/200212160857 ... ION=Global
Other micros:
http://web.archive.org/web/200212020709 ... ION=Global
PostPosted: November 16th, 2015, 21:14
fzabkar,
thank you. But
Hrm.
Wayback Machine doesn't have that page archived.
Want to search for all archived pages under http://www.mitsubishichips.com/common/cfm/ ?
PostPosted: November 16th, 2015, 21:16
ScanROM. unlock without using SafeMode.
PostPosted: November 16th, 2015, 21:26
How could that be? Missing the logic here...the archive.org link clearly states that the page version is from 2002 ;)
PostPosted: November 16th, 2015, 21:37
drHDD, what are system modules?
Are you talking about what's described here? http://www.datarecovery.net/articles/ha ... -area.aspx
If yes, how can I do that?
PostPosted: November 16th, 2015, 21:38
Sorry, it was a syntax error. I did mean 2002. :-)
PostPosted: November 17th, 2015, 2:31
I swapped the heads, but I made it worse. I managed to touch the platter with my finger when I was removing the old heads, so there's a small print there now. I was also successful in allowing the new heads to touch and bang against the plastic thingie in which they're parked.
Result: It behaves exactly the same. I tried to switch EEPROMs, boards, no luck.
Should I give it another try with a new head assembly?
PostPosted: November 17th, 2015, 3:12
Ok... I did another little experiment. I was going to trash the HDD I bought off of e-bay, but I figured I should put the old heads in and see if it works. They did touch and they were out of the HDD for a lot longer and I also managed to spit on the platters of this one as I was trying to blow some dust that fell off of the case when I took it apart.
Before I put the heads in, I put them under the microscope and I saw that the actual head is guarded by the outer shell (which I originally thought that it holds the head on its tip) so bending them or knocking them off of their position seems unlikely even when handled without too much care.
About the spacer that I've seen being used in several videos to keep the heads from touching, when you're removing them - I don't think they're necessary either, because the heads don't touch, instead the little material that makes it float touches with the one from the other head, while the head is recessed a bit, above the level of contact.
Bottom line: the one from e-bay works with the heads and the PCB from the broken one. The borken one still doesn't work.
What could this mean? Is there something wrong stored in the service area?
PostPosted: November 17th, 2015, 8:27
How did you test determining the heads are fully working?
PostPosted: November 17th, 2015, 9:17
I'm not 100% sure they're fully working (although I suspect they would be tested, no?), but the e-bay drive gets recognized by the BIOS, just like before, while my drive doesn't, just like before.
PostPosted: November 17th, 2015, 14:30
If visible in Windows, check with hddscan. If not, try MHDD.
Users browsing this forum: No registered users and 152 guests
