 Post subject: help to find donor drive for wd10ealx
PostPosted: November 17th, 2015, 12:44
I want to find a donor (head swap) for drive WD10EALX-009BA.
i know that model and firmware must mach, but there is no firmware number indicated on the drive.
can someone explain, what numbers must match when finding Western Digital donor drives
WWN: 50014EE2B0F88183
DATE: 31 AUG 2011
DCM: EANNHTJCAB
DCX:3005998B2
FOTO
https://drive.google.com/file/d/0B9FnilkuXP4AY0VTdjd0bUJBb1k/view?usp=sharing
 Post subject: Re: help to find donor drive for wd10ealx
PostPosted: November 17th, 2015, 16:21
can you upload the ROM ?
PostPosted: November 17th, 2015, 16:28
The one pictured here probably will work (just be sure you get the right one), though the date is a bit further off than I'd normally shoot for:
http://www.ebay.com/itm/Western-Digital ... SwIrNWFE5Z
This one will probably work too: http://www.ebay.com/itm/1-TB-Western-Di ... SwpDdVT8tk
PostPosted: November 17th, 2015, 16:40
apparently there are 2 types (at least that i know of) of preamp rev. made around that time
PostPosted: November 17th, 2015, 16:50
Yes, but unless you find the drive on a site like donordrives.com and they actually have the preamp listed, you'll have no way to know which one you're getting until you've already bought it anyway.
PostPosted: November 18th, 2015, 16:32
Ive some in stock. I Can confirm tomorrow.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: November 19th, 2015, 9:16
This Is what i have. Most close
__________
THANK YOU
SHAHI
PostPosted: November 19th, 2015, 16:33
Looks suitable to me
PostPosted: November 19th, 2015, 16:59
+1
i like the DOM
PostPosted: November 19th, 2015, 17:01
Family Tahoe 2d has only one configuration.
You can use any:
WD10EALS-002BA0
WD10EAKS-007AA0
WD1001FALS-00E3A0
WD1002FAEX-00Z3A0
WD10EALS-00Z8A0
The only problem could be if some of the heads will have too high recording density compared with the density of the same head at the donor.
DCM does not need to look.
PostPosted: November 23rd, 2015, 14:06
thank you for support, i have found the donor.
PostPosted: November 23rd, 2015, 16:23
You can use any:
WD10EAKS-007AA0
:shock:
I've never come across these in the wild.
But probably you were referring to WD10EACS-007AA0 instead?
(even though the alphanumeric code after the hyphen didn't match with anything I was looking through)
PostPosted: November 23rd, 2015, 16:36
syntaxerror,
at WD, and there are no such troubles.
I have not written everything
also Tahoe 2d
WD1001FALS-403AA0
WD1001AALS-00E3A0
And probably still is.
Users browsing this forum: No registered users and 110 guests
