 Post subject: my passport ultra WD usb 3.0 2tb
PostPosted: November 18th, 2015, 6:30
i bought it in june 2015, it worked 100% good
i droped it about 3 feet onto a hardwood floor and now it doesnt work
when i plug it in the light comes on and blinks
it shows up in device manager
when i go to the device manager properties and go to volumes and click populate it just loads forever and never actually loads
 Post subject: Re: my passport ultra WD usb 3.0 2tb
PostPosted: November 18th, 2015, 6:49
if the data is important my advice would be to send it to a DR firm (not a computer repair shop)
PostPosted: November 18th, 2015, 16:41
Spildit wrote:
+1
If you need to recover the data this is your only viable option.
Regards and good luck.
+2
Absolutely nothing you can do yourself.
PostPosted: November 20th, 2015, 7:53
thankyou for the timely responses, i am not sure if this makes a difference but:
if i use MiniTool Partition Wizard Free it loads the hard drives for a long time and won't load but if i loosen then usb to the external 2tb hdd that is broken but not completely remove it, it shows up and i can "fix MBR" and use "explore partition" (it takes a long long time to "fix MBR") and when i explore partition it shows the director tree of my stuff... if i unplug it and plug it back in i have to fix the mbr again before i can see anything
does this change anything or is there still nothing i can do myself?
PostPosted: November 20th, 2015, 9:07
data is important sent to professional
PostPosted: November 20th, 2015, 9:24
pcimage wrote:
Spildit wrote:
+1
+2
+3
are you absolutely 100% sure that disk is spinning just fine and has no abnormal, clicking noise ?
can you record sound and upload here ?
Data Recovery Pakistan
PostPosted: November 20th, 2015, 10:09
MindMergepk wrote:
pcimage wrote:
Spildit wrote:
+1
+2
+3
i noticed no clicking noises... see my update about mbr
PostPosted: November 21st, 2015, 2:08
honestly it is dangerous to play with disk which is dropped.
however i can assist you further to diagnose it if there is absolutely no abnormal noise.
leave Team viewer details here.
PostPosted: November 21st, 2015, 2:53
+4 if u want data send it to DR profesional
Expect, the Unexpected
PostPosted: November 26th, 2015, 9:17
ive never used team viewer before should we arrange a specific time?
you can contact me on skype? mathy10544
my teamviewer is 214 765 842
pw is 4293
PostPosted: November 26th, 2015, 9:45
he said
but you didn't respond
PostPosted: November 26th, 2015, 11:20
pw is 4293
Giving your tv details in public is generally a bad idea. :mrgreen:
PostPosted: November 26th, 2015, 11:24
just added on skype.
Users browsing this forum: Google [Bot] and 258 guests
