 Post subject: WD Jamaica 4V LDR req'd...
PostPosted: November 23rd, 2015, 5:54
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 256
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 15.2CT
ROM generation.......................... : 15.2CT
Link table version...................... : 08.02.
Consolidated ROM version................ : 0015002C
ROM Modules:
Flash ROM dir reading................... : Ok
SA Translator loading................... : Ok
SA defects assigned..................... : 1
Heads configuration..................... : by map
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
ROM Firmware version.................... : 0015002C
Thanks in advance!! :-)
 Post subject: Re: WD Jamaica 4V LDR req'd...
PostPosted: November 23rd, 2015, 6:54
Check it do not have that version
ZeBong
" Россия еще раз"
PostPosted: November 23rd, 2015, 7:47
pcimage wrote:
Techno mode key
RAM:
ROM:
ROM Modules:
This should get you access the closest 0015002F
ROM +LDR
good luck
0015002F.rar [379.29 KiB]
Downloaded 635 times
PostPosted: November 23rd, 2015, 11:32
Sorry, I was looking at the ROM info from the potential hotswap drive.
This is the actual one I need! ........
Techno mode key
RAM:
ROM:
ROM version............................. : 15.3HU
ROM generation.......................... : 15.3HU
Link table version...................... : 07.22.
Consolidated ROM version................ : 0015003H
ROM Modules:
ROM Firmware version.................... : 0015003H
PostPosted: December 1st, 2015, 16:50
Here's a copy of module 11 and all modules I was able to access. You wouldn't happen the 15.3HU rom would you? I believe my copy of the rom is corrupt and unfortunately I have no access to module 109 to regenerate.
WDC WD3200BPVT-55ZEST0-15003H-WD-WX31EB1TYH18.zip [8.25 MiB]
Downloaded 514 times
cron
