 Post subject: how to convert USB to SATA in a Samsung HM100UX
PostPosted: June 28th, 2013, 11:57
Hello Guys,
I have a USB 2.0 1Tb 2.5 Samsung HM100UX. There is something wrong with the usb connection. When I connect the usb cable the pcb does nothing, no lights. I was able to find a power point in the board like you can see in the pictures and I can power up the drive, light shows and motor spins. Tried to connect the usb cable at the same time but the drive spins for a minute and then stops.
I think the only solution is to convert it to sata connection. Can anyone tell me the sata connection locations?
http://gyazo.com/e64b6a82f8fa8a755524b519b7dfecc5
http://gyazo.com/9bf9183243dc285630d8444da2fe2a97
Thanks guys :D
 Post subject: Re: how to convert USB to SATA in a Samsung HM100UX
PostPosted: June 29th, 2013, 3:35
FWIW, there was a fairly recent thread where the solution was to reflow a dry solder joint at a chip inductor near the USB connector. Might be worth a look ...
viewtopic.php?f=1&t=25581&p=174993
The attachment shows the SATA Tx/Rx coupling capacitors ... I think.
PostPosted: November 25th, 2015, 14:05
the post is two years old but I have same problem. Upload pinout JM20339 and datasheet. It could be helpful to other users. :wink:
JM20339_datasheet_v2.3.pdf [440.16 KiB]
Downloaded 1918 times
