 Post subject: Encrypted? WD My Book Essentials 2 TB
PostPosted: November 28th, 2015, 6:32
Hello folks,
the USB Controller board had an oversurge. Electronical Part U5 (left top) seems to be faulty. As far as I have understood the case the drive seems to be some kind of hardware encrypted.
    Is there a way to get the data back with repairing or even without repairing (identify the chip - desolder - solder new chip) the USB-Sata Interface?
    As I understood it the encryption key is stored in the SA (module 25)?
maybe a stupid question.. ;-)
    I made an Image with ddresuce but somehow the following information means that it is useless. Isn't it? Is there a way to make an proper image and determine the encryption key and get the data back without repairing or replacing the usb-sata adapter?
quote source: viewtopic.php?f=1&t=19408
(1) My Book Essentials drives are encrypted. You need the original USB-SATA bridge PCB to decrypt them.
(2) The 3TB My Books are configured with 4KB LBAs. When you remove the drive from its enclosure, you expose its native 512e LBAs. This means that, even if your drive were not encrypted (eg My Book Elements), you would still need an enclosure that is configured with the same 4KB sector size as your WD enclosure.
Greetings from Germany
Benjamin
edit:
found some further information on this topic:
viewtopic.php?f=1&t=17398&start=120
Fachwerkstatt für Data Recovery / Datenrettung in Stuttgart - Riedel IT - Ameisenbergstraße 30 - 70188 Stuttgart
 Post subject: Re: Encrypted? WD My Book Essentials 2 TB
PostPosted: November 28th, 2015, 6:53
bought a
4061-705094-001 Rev AE WD Controller Board My Book Essential
PostPosted: November 28th, 2015, 10:18
the faulty electronic component U5 seems to be the following:
2A, 23V, 340kHz Synchronous Step-Down Converter - Datasheet
http://www.farnell.com/datasheets/1782089.pdf
this picture helped - there I saw RT8284
https://cdn.discourse.org/wd/uploads/de ... 302094.jpg
Does anyone now a component which is compatible to RT8284?
PostPosted: November 28th, 2015, 11:16
http://www.richtek.com/assets/product_f ... 84N-03.pdf
This component R8284N has the same specs (as I can see) and is on stock.
PostPosted: November 30th, 2015, 8:09
get another interface board with same encryption chip. Or invest in some proper tools.
PostPosted: November 30th, 2015, 10:05
+1
PostPosted: December 1st, 2015, 10:42
Izualim wrote:
+1
+2
Data Recovery Pakistan
PostPosted: December 2nd, 2015, 7:40
Guys, the board came (i ordered it on friday) and the data is already saved. Nevertheless I bought the blown dc stepdown converter because I'm that curious to fix the other board!
Maybe there might be another solution to fix the board - I'm checking that right now..
PostPosted: December 2nd, 2015, 15:17
The DC-DC converter generates the +5V supply for the HDD. If all you wanted was your data, you could have solved the original problem with 3 wires. Just remove U5 by snipping its pins with flush cutters. Then run an external +5V supply from your PC's PSU to the load side of the 150 coil (L1). Also run an external +12V supply and ground from the same PSU to DC connector J3.
Of course an actual repair would be much more elegant. :-)
PostPosted: December 2nd, 2015, 16:14
fzabkar - thank you for you contribution! This article you sent me was very helpful. I'll check that:
http://www.hddoracle.com/viewtopic.php? ... =155&p=311
PostPosted: December 2nd, 2015, 16:21
As I explained to you privately, that article is about a different problem, but the solution is similar.
PostPosted: December 3rd, 2015, 1:10
Here is another article that might be helpful to you:
Western Digital My Book Essential bridge PCB, 4061-705094:
http://www.hddoracle.com/viewtopic.php?f=112&t=1032
PostPosted: June 5th, 2017, 17:55
I have been asked to indicate the connections points for an external 5V/12V supply.
PostPosted: June 5th, 2017, 18:47
Waking up some dry bones with this thread. I think by now Benjamin probably owns a PC-3000 and can handle these cases without fixing the bridge. :D
PostPosted: June 5th, 2017, 18:55
I was responding publicly to a PM which referenced this thread. Evidently there are people who prefer employing 3 wires rather than purchasing whatever hardware or software others may deem necessary. :|
Users browsing this forum: Pi0tR and 54 guests
