Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
 Post subject: TOSHIBA DT01ACA050 HDD PCB Burn
PostPosted: December 2nd, 2015, 3:31
Dear Friend's,
I Have a TOSHIBA DT01ACA050 HDD,
This HDD PCB burn, so i am replace NEW same model number PCB and Swap ROM Chip.
But Still Not power up motor. But MRT tool show PWR / DRD / DSC ready mode.
Please help to me recovery this hard disk data.
 Post subject: Re: TOSHIBA DT01ACA050 HDD PCB Burn
PostPosted: December 2nd, 2015, 4:01
Dear Friend,
Thanks for your post.
i am very carefully replace ROM chip,
and i can read ROM chip data.(see attach picture file)
[img]file:///C:/Users/PC/Downloads/rom%20data.png[/img]
also i am try with 2-3 same model PCB. but Still same :(
please help to me ...!
PostPosted: December 2nd, 2015, 4:24
i am replace ROM CHIP very carefully, and i am try with Same ROM chip with 2-3 PCB.
but still have a same problem.
also i can read ROM chip data in MRT rom program section.
please advice to me recovery method.
PostPosted: December 2nd, 2015, 4:33
can you provide pics of both pcbs , (patient and donor )
PostPosted: December 2nd, 2015, 4:49
yes,
i can.
please find attach picture file's
PostPosted: December 2nd, 2015, 5:05
Spildit wrote:
Or more likely maybe the pre-amp got toasted as well when your pcb got damaged ?
+1 yep, probably preamp
PostPosted: December 2nd, 2015, 5:17
Ok so your motor controller has burnt out. Most likely you have much worse internal issues, such as heads stuck on platters which has caused it to burn out in the first place. Really it's lucky it doesn't spin anymore so at least you won't be able to do further damage. It will need to be opened in a cleanroom by someone with experience in this type of work, and any damage inspected and repaired before proceeding to spin up the drive again.
PostPosted: December 2nd, 2015, 5:43
i am sure motor working well,
because i am put donor PCB like attachment picture method.
then spin up motor and after few second spin down.
PostPosted: December 2nd, 2015, 5:47
no one said anything about the motor, he said motor controller
the problem is with the HSA
PostPosted: December 2nd, 2015, 5:55
That mean need to replace head ?
PostPosted: December 2nd, 2015, 5:58
most likely (hopefully there is no media damage)
PostPosted: December 2nd, 2015, 14:39
The damage to the motor controller IC appears to be on the 5V side. The MCU also appears to be cooked. It's only academic now, but the OP could test the TVS diodes and fuses (?) to see whether the damage was due to an external overvoltage.
To confirm whether the preamp is shorted, I would measure the resistance between ground and each of the preamp supply rails.
PostPosted: December 2nd, 2015, 16:56
Only you can see that file. Can you upload the BIN/ZIP version of the "ROM"?
It won't matter for a physical ROM transfer, but be aware that MRT's Programming Unit has a serious bug that prevents it from reading ROMs without corruption, at least in some cases. If MRT can read the ROM in-circuit, then I would compare the in-circuit dump against the one you obtained via the Programming Unit.
PostPosted: December 3rd, 2015, 8:03
please find attach ROM data file.
PostPosted: December 3rd, 2015, 9:42
it's not a toshiba drive it's an hitachi ibm arm drive
do you have the NVRAM ?
hammm, actually it's in the ROM
PostPosted: December 3rd, 2015, 9:48
i'm not familiar with MRT
connect the drive and flash the NVRAM see if there is a diff.
PostPosted: December 3rd, 2015, 10:05
this is the NVRAM extracted from your ROM
nvram.zip [1.88 KiB]
Downloaded 1210 times
PostPosted: December 3rd, 2015, 14:04
Hi Jermy ,
Are These New Arm Series All Having NVRAM Inside ROM .What Offset It This At And Whats The Length Brother .I Was Thinking Its In MCU .So In His Case If Its Inside ROM And He Has Swapped The ROM Definitely Its a Preamp Complete Headstack Failure
PostPosted: December 3rd, 2015, 14:06
Hi ,
Which Bug Are You Referring Too ? .
PostPosted: December 3rd, 2015, 15:02
Amarbir wrote:
What Offset It This At And Whats The Length Brother.
@ 0x2000 length of 0x1000 and there is also a copy right after @0x3000
Amarbir wrote:
I Was Thinking Its In MCU.
apparently not
i have to agree
