 Post subject: When DIY goes wrong, yet again!
PostPosted: December 2nd, 2015, 8:55
Allegedly done by a local "PC expert guy" (Not UK) ...
Exactly as we received it.
So many issues it's almost laughable :-(
 Post subject: Re: When DIY goes wrong, yet again!
PostPosted: December 2nd, 2015, 9:29
Guess there is no denying that they were messing with the platters, eh?
PostPosted: December 2nd, 2015, 9:42
but you can fix it, right ;)
PostPosted: December 2nd, 2015, 9:43
Sean Sir ,
Damaged Seems To Be On Top Platter ,Might Be you Can Clean It ,Install New Heads And Try Out i Give it 50% Chance of Recovery And In Your Expert Hands Might Be 75%
PostPosted: December 2nd, 2015, 11:27
Top platter also has radial "slipped screwdriver" scratches on it too :-(
Who knows the order and what way up the platters are meant to be, and what damage caused by the platters being pressed against each other.
I've backed out of this one!
PostPosted: December 2nd, 2015, 12:16
Amarbir wrote:
Sean Sir ,
50% chance!!! are you crazy, I'd give that a 2% chance of getting so much as a single sector read. Anyone who's dumb enough to have messed around with the platters like that has also tried every DIY hack technique in the book. I'm sure it's already spent a night and a day in the freezer, been brutalized with Spinrite, left clicking for a couple of days, etc.
Quote $1000 + parts with no guarantees of getting any data back. That's what I would do.
PostPosted: December 2nd, 2015, 12:26
$1000? I'd be thinking an up front fee of $5000 for the attempt and an extra $5000 if we are able to recover anything at all. Then give them a list of labs who claim a 99% success rate.
PostPosted: December 2nd, 2015, 12:52
Not sure but are those blood stains I can see towards the bottom right? :shock:
PostPosted: December 2nd, 2015, 13:28
They just "opened it, looked inside, and closed it", I presume...
This is totally FUBAR.
PostPosted: December 2nd, 2015, 16:05
No, they are marker pen marks.
Haven't checked this one, but the last two drives we had in from this dealer (who says they came in from another "data recovery company") had the same marks on the base along with similar marks on the platter edges, presumably a futile attempt at platter alignment.
One of the last ones had so much ink splodged on it that it had seeped onto the platter and had coloured the head sliders purple when looked at under a microscope! It was a Samsung HM100UI that shows an "unpack error" in terminal with no spin. Any half decent pro would recognise this fault and know that this guy almost certainly had no business switching the 3 platters to another chassis and getting fingerprints on all 6 surfaces :-(
PostPosted: December 3rd, 2015, 19:26
oh wow, that looks nasty.
PostPosted: December 4th, 2015, 17:22
:shock:
How does that phrase begin again?
"There's a special place in hell....
Голод не тётка!
PostPosted: December 14th, 2015, 9:21
I hope you do not get to many jobs from that dealer Sean :shock:
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: December 14th, 2015, 15:31
Unfortunately (for the clients) most of the jobs from this particular chap are butchered to some extent :-(
PostPosted: December 14th, 2015, 18:46
i assume that the rest of them is become expensive :(
PostPosted: December 17th, 2015, 7:50
Got one today that was also opened by the client first.... :shock: :shock: :shock:
Filter full of debris and all over the chassis too.
ACELab partner
PostPosted: December 17th, 2015, 8:07
its dandruff from scratching their head trying to make sense of whats in there!
PostPosted: December 17th, 2015, 15:03
:mrgreen: :mrgreen:
ACELab partner
PostPosted: December 20th, 2015, 10:12
Its not only DIY that goes wrong, I got two drives in from two different DR companies that claim to offer clean-room labs in Germany: "device has been handled under appropriate clean-room conditions".
Opened one drive today and there was a mess, not only limiter & filter missing but fingerprints & dust everywhere :evil: . And what was really sad, they did not even checked pcb contacts first - might have been the problem the drive had in the first place ...
cron
