 Post subject: Sandpaper [ Emery Paper ] - Grit Size Question
PostPosted: December 3rd, 2015, 12:15
Hello ,
I Am Having a Tough Time Arranging Preferred Grit Size Paper For Removing Coating On Monoliths .Could You Please Send Me Some Of Your Preferred Numbers .Really Appreciate That So That i Can Retry Again Tomorrow
 Post subject: Re: Sandpaper [ Emery Paper ] - Grit Size Question
PostPosted: December 3rd, 2015, 12:39
Amarbir wrote:
Hello ,
I completed the Ace Labs Flash training class a little while ago, and they were recommending 1200, then 2000, then 2500 grit. I have found this is supplied by a lot of jewelry suppliers.
PostPosted: December 3rd, 2015, 13:52
ddrecovery wrote:
Amarbir wrote:
Hello ,
Hi Boss ,
I Only Found 1000 and 2000 today will ask them for 1200 and 2500 also tomorrow
PostPosted: December 3rd, 2015, 15:08
I use just 1200. but what about the fibreglass scratch pen? you are only removing the coating..
PostPosted: December 3rd, 2015, 16:18
Use a high pressure water jet, you can dial in the specific pressure you want, other solutions are a dremel on a CNC machine. Some use 100-300 grit sandpaper, but I don't recommend.. you have many options. CNC + Dremel is the best IMHO at ~$250-$300. You can also experiment with different varnish removers, see which ones work in your locality.
Fiberglass anything scares me
I'll mail you a monolithic, compare it to ace and tell me what you think ;-)
One of the many reasons I laugh when Ace Labs says they are skilled in monolithics..
Recover My Flash Drive
PostPosted: December 3rd, 2015, 18:57
Really, you just need to get down to the copper and have it clean enough to solder to. you don't even need to clean the whole thing off.
wet and dry sandpaper is what is used to prepare cars for re-spraying. available at any hardware or auto parts shop
PostPosted: December 3rd, 2015, 19:48
You don't recommend removing the PCB and soldering directly to the wire bonds? It's less trouble than figuring out pin-outs..
PostPosted: December 3rd, 2015, 21:34
I think I know what you mean, and this is the general idea for that: https://www.youtube.com/watch?v=dQw4w9WgXcQ
PostPosted: December 3rd, 2015, 23:52
That was the basic idea..
How about Sand blasting?
http://components.about.com/od/Design/a ... r-Mask.htm
PostPosted: December 4th, 2015, 0:28
The downside to microblastic systems is the generation of static electricity which can destroy ESD sensitive components on the circuit board
PostPosted: December 4th, 2015, 4:13
Hi Everyone ,
Thanks For Some Inputs By All Of You .
PostPosted: December 9th, 2015, 17:51
+1 for fiberglass pen - always works great :)
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: December 9th, 2015, 19:44
This does look like it would work well: https://www.youtube.com/watch?v=nKjvrDCktpw
I don't do monoliths, but it seems to clean up a pcb pretty easily.
PostPosted: December 9th, 2015, 20:59
@data-medics this is a fiberglass pen
PostPosted: December 9th, 2015, 22:34
And the video is by Joe grand - he does some cool stuff like making the defcon badges, and JTAGulator.
Users browsing this forum: No registered users and 101 guests
