 Post subject: First Attempt - Monolith Plastic Coating Removal
PostPosted: December 4th, 2015, 10:23
Hello Everyone ,
Today i Tried 1 Monolith MMC Card .This is What i Got In The End .Can Some Seniors Tell Me If This Pinout Is Know ? . Its a Dead Card When Connected To Computer Using Kingston Card Reader .
The Actual Card Photo [ Side A And Side B ]
The Photo Of The Monolith After Coating Removal
PS : Have a Few Questions Will Ask
 Post subject: Re: First Attempt - Monolith Plastic Coating Removal
PostPosted: December 4th, 2015, 10:54
IMHO, I would start with something a lot simpler.
but this may help:
http://www.hardwarebook.info/MMCplus
PostPosted: December 4th, 2015, 11:00
but this may help:
Ha haaa ,
Haque Sir Just Greasing My Hands With that Black Filthy Plastic :mrgreen: .I Have a Few Questions For You All .If You See This Picture You Will realize The Coating is Not Removed In Few Tighter Spots Like Between Main Card Reader Connection .How does One Target Focus On That Area .The 1000 Grit Paper Was Used Initially And Then the 2000 .Would Like To Take a suggestion When To Flip The Sandpaper From 1000/1200 To 2000 .The Fiber Pen Was Too Abrasive
PostPosted: December 4th, 2015, 11:13
you don't need to get it all off. on normal monoliths, you would solder to parts such as circled. NOTE- these are not the right points, I don't have this pinout available, this is only an example.
The only reason you would remove all coating, is for a catalog photo to ID like devices in the future. If you know the pinout, you only need remove coating to expose these solder points and that's all. we are not making beautiful art here, we are recovering DATA!! ;-)
these may lead you in the right direction:
http://elm-chan.org/docs/mmc/mmc_e.html
http://www.nxp.com/documents/application_note/AN10406.pdf
http://www.retroleum.co.uk/electronics-articles/basic-mmc-card-access/
http://www.dejazzer.com/ee379/lecture_notes/lec12_sd_card.pdf
PostPosted: December 4th, 2015, 12:18
Sir ,
You Are Always Very Supportive ,Thanks From The Bottom Of My Heart .You Know i Am Heading To This Field Of Recovery And Its Tough a Hint Here and There Helps + All The Hard Work i will Pour In .
Users browsing this forum: Google [Bot] and 38 guests
