 Post subject: HELP!!! Maxtor 6Y080L0 problem
PostPosted: December 30th, 2004, 0:15
My Maxtor 6Y080L0422001 dies out suddently with sound of touching head. Upon system reboot, only showing "CALYPSO YAR43KJZ" instead of proper HDD information. Is anyway to save all precise information from this hdd via MHDD (or possibly other utility)?
:cry: :cry: :cry:
 Post subject: Re: HELP!!! Maxtor 6Y080L0 problem
PostPosted: December 30th, 2004, 2:09
:cry: :cry: :cry:
MHDD will not repair this problem.
If you need the data you will do best to contact a DR service.
 Post subject:
PostPosted: December 30th, 2004, 5:40
Thanks for quick reply but if it hints what sort of problem is my hdd facing?
 Post subject:
PostPosted: December 30th, 2004, 7:55
Hi, your hard disk has a problem that is called System Engeneering problem, this means that part of the reserved area ( area that is used by the manufactur ) has a problem, and can be many things like ID or one of the defects lists.
The best thing to you ( IMHO ) is look for a repair center, here has people from many parts of world.
 Post subject:
PostPosted: December 30th, 2004, 20:19
Or You can reed forums and learn Your self
Nikol
 Post subject:
PostPosted: January 2nd, 2005, 17:37
Ive got the same problem with mine diamond max 9 160Gb - could you give us some links to topics related to this problem ? thanks in advance
 Post subject:
PostPosted: January 2nd, 2005, 17:45
http://www.google.com
one size fits all
 Post subject:
PostPosted: January 2nd, 2005, 17:51
hahaha:) thanx. one more quest. can it be fixed without pc3000 ?
 Post subject:
PostPosted: January 2nd, 2005, 18:05
Yes
 Post subject:
PostPosted: January 2nd, 2005, 18:31
thats good because i dont have it. From reading topics i figured that i have to get drives P-LIST, G-LIST, RZTBL but i dont really know what it is:) I have to extract it , write it to drive once again. Also check if the SA has bad blocks. But please tell me where to get software to do all this and if its not a big problem some faq's or manuals. Thanks in advance!!
Users browsing this forum: huangmiaofang and 72 guests
