 Post subject: I want to spend copious amounts of money on a shorting tool
PostPosted: December 5th, 2015, 12:06
The paper clip/tweezer solution for shorting TP's to access terminal is not regal enough for me. :lol:
I've seen a very fancy tool that was specifically made for the job on the internet somewhere but cant seem to find it any more.
Does anyone know what I'm talking about or which site its on?
 Post subject: Re: I want to spend copious amounts of money on a shorting
PostPosted: December 5th, 2015, 12:37
I did find this one but I thought there was one that was all metal?
PostPosted: December 5th, 2015, 21:34
maybe you meant this one ?
PostPosted: December 5th, 2015, 22:06
I like this idea:
http://images.ffx.co.uk/tools/FAIDIV6.JPG
PostPosted: December 5th, 2015, 22:21
I like this idea:
the problem with this one is, to gain access to seagate drives the short has to be done in a certain point
PostPosted: December 5th, 2015, 22:31
jermy wrote:
I like this idea:
I understand, but ISTM that you could still do it with a divider.
Anyway, here is the original (?) thread:
viewtopic.php?f=13&t=30761
PostPosted: December 6th, 2015, 10:55
Thanks for the posts guys those are the two that I found.
I thought there was another one, but maybe not.
PostPosted: December 6th, 2015, 11:14
I was able to find the read /write channels on most drives due to lots of detailed posts on here. Are you aware of any posts that describe the exact procedure (timing) etc when using any of these tools on any particular drive?
PostPosted: December 6th, 2015, 11:39
http://blog.acelaboratory.com/where-and ... rives.html
PostPosted: December 6th, 2015, 19:12
That's exactly what I was looking for, thanks!
PostPosted: December 6th, 2015, 20:24
jermy wrote:
http://blog.acelaboratory.com/where-and-how-to-short-seagate-f3-drives.html
At some drives there is no resistor on both lines – so only one way to find read channel is to check both differential pair
There is a better way that doesn't involve trial-and-error.
How to identify the Read Channel when no terminators:
http://www.hddoracle.com/viewtopic.php?f=24&t=123&p=149
