 Post subject: SA Defect
PostPosted: December 31st, 2004, 5:46
Help. i have a sa defect in my hd. How can i fix it. The defect is in the defect table module. Can i edit defect table manualy, how ?
Best Regards,
e-win
 Post subject:
PostPosted: December 31st, 2004, 8:02
You have SA defect in your HD ? or your HD has defect in SA ?
And what this means ?
The arear where is recorded the Firmware has bads ? or you have a module that is demage and are you sure about the module and what is the module is the P-List or the G-List ? also I would like to hear about the "ëdit mode" to fix the defect list of a hard disk.
This is not the same problem.
Also is very hard to advice when we even do not know what is the brand of the hard disks, what is its size and bla bla bla .......
 Post subject:
PostPosted: December 31st, 2004, 8:11
you can use THDD to add the defect in the G-list. if the defect in the negative area . you should use HRT to fix it. only HRT can fix bad track in the negative track.
MSN message :mymba2002@hotmail.com
 Post subject:
PostPosted: January 6th, 2005, 23:17
Does someone know the link to HRT?
 Post subject:
PostPosted: January 7th, 2005, 2:26
That will better
[deleted by moderator]
 Post subject:
PostPosted: January 11th, 2005, 5:02
don't download above linked file. if you run your hard disk will be locked and user passwords be set in windows.
Users browsing this forum: No registered users and 240 guests
