Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
 Post subject: Re: TOSHIBA DT01ACA050 HDD PCB Burn
PostPosted: December 3rd, 2015, 15:07
damindaniroshana wrote:
please find attach ROM data file.
Some versions of MRT's hardware/software will randomly drop 32-bit dwords when reading a chip via the Programming Unit (I have seen this on two separate systems). Your ROM dump looks OK in this respect, so it appears that your setup is not affected by this bug.
Here is one example of the problem:
viewtopic.php?t=31819&p=223334#p223334
PostPosted: December 4th, 2015, 4:16
Frank , Spildit And Jermy ,
Thanks For The inputs Brothers .I Too have a Case That i Like To Check But its a Hitachi And According To Me There is a 50% Thats Its The PCB .Will Keep You Folks Posted
PostPosted: December 8th, 2015, 8:24
please find this HDD picture file.
PostPosted: December 8th, 2015, 8:25
please find this hard disk picture file.
PostPosted: December 8th, 2015, 9:37
what's the picture for ?
PostPosted: December 8th, 2015, 9:43
can i know donor match method for head swap process ?
PostPosted: December 8th, 2015, 10:40
There is also a posibility that motor is faulty and hard drive dont want to start. How the drive failed?
Recuperacion De Datos Dominican Republic
PostPosted: December 9th, 2015, 0:40
This HDD motor working well.
I am tested that.
PostPosted: December 9th, 2015, 6:10
replace the HSA + a good working PCB and and get it over with
PostPosted: January 9th, 2021, 8:58
Hello people. I am facing a problem with same type of hdd on this thread. On boot Bios identifies it with: Smart event (asus mb). After windows starts i can see all 3 partitions but no acces to any of them. Hdd gets warm and spinning. I got another pcb from a dismantled good hdd with same specifications. Can anyone hint me somehow. Whenever I try start windows with this hdd connected it takes a lot to start. I have to start windows with hdd disconnected. When I connect it to pcb it takes 30seconds until windows gets stuck.
PostPosted: January 19th, 2021, 10:42
Wich one Is rom chip please?
PostPosted: January 19th, 2021, 15:35
I actually just changed reading head hsa. And revived all partitions except one ...Parameter is invalid :(. The most important. I can copy some folders with testdisk. Have any other solution please?
PostPosted: January 19th, 2021, 16:43
Clone the drive with HDDSuperClone.
You could try to disable ARRE (Automatic Read Reallocation Enable) via terminal using the SP command:
https://forum.hddguru.com/viewtopic.php?f=1&t=28168
Doing so should hopefully stabilise the drive.
PostPosted: January 19th, 2021, 17:18
It's a Hitachi- HDS721050DLE630 labelled by Toshiba
PostPosted: May 7th, 2024, 13:09
I have DT01ACA050 . Look like ROM not original.
Is it possible to access data? Is Toshiba branded HTC ROM Unique?
Tried so many hot swap . no result
Sexy Womans from your town
